S.e.s.???
Old Jun 28, 2003 | 12:57 PM
spoonjimlt1's Avatar
S.e.s.???
my SES light just turned on in my car last night. Now i just put in a 160 stat a free fan switch (it grounds the relay with a switch) and my oil change light went on cause when i changed the oil about 1000 miles ago i didnt put the last half quart in. could any of the things set the code for the light.
Old Jun 28, 2003 | 05:11 PM
amood's Avatar
you need to go to the dealership and have them pull the code to find out what is wrong....it doesn't much matter if what you did set the code or not. Could be, but may not be....see what I mean?
Old Jun 28, 2003 | 05:14 PM
LS1-Maniac's Avatar
I'd go to Autozone and let them scan your car. It's free there and the usually have good advice as to how to fix the problem.
Old Jun 28, 2003 | 05:21 PM
stik6shift98's Avatar
yup....or come here and i can pull the code for you....
Old Jun 28, 2003 | 09:32 PM
Ferocity02's Avatar
You guys are lucky to have good Autozones, none of them around here pull codes anymore, bastards
Old Jun 29, 2003 | 02:48 PM
thanks guys
im gonna check the code at school.
and its off now so it couldnt have been a bad one.
JIM
Old Jun 29, 2003 | 04:41 PM
LS1-Maniac's Avatar
Have you put gas in your car recently? If so it was probably the gas-cap code. If you tighten your gas cap too much it sets a code, if you dont tighten it enough it sets a code. 3 clicks then you stop. It took me a while to figure out that was what was giving me codes on my camaro.
Old Jun 30, 2003 | 12:37 AM
i never got that code??????
weird??
oneclean97z
Jul 20, 2008 02:51 PM
flounder564
May 31, 2005 03:50 PM
OreoLT1
Apr 26, 2005 04:36 PM
Eddie95Z28
Apr 27, 2003 12:33 PM
Eddie95Z28
Sep 26, 2002 06:03 PM
