Whine at 60mph to 65mph
Old Jun 21, 2003 | 01:19 PM
CODY BEHNKE's Avatar
I have a slight rear end whine from 60-65mph, it is there when I am appling the gas but goes away when I let off. It's only really noticeable in the 60-65 area. Any ideas, my fron pinion seal was leaking ? Bearing out ?
Old Jun 21, 2003 | 09:49 PM
blacknight's Avatar
Mine has the same problem and was like this when new. Went to two dealers and both said they couldn't hear any whine. Bunch of deaf ********.
Old Jun 21, 2003 | 10:21 PM
norcalstreet's Avatar
If this just started happening and you've had your gears for a while it may be a sign of your gears going out of alignment. I would check for leaks at the pinion seal and cover seal.
Old Jun 22, 2003 | 09:09 AM
I had a pinion seal leak and repaired it, got me thinking though.
I am pretty sure I have a pinion bearing that went bad. The gear lube is toast from heat.
2QUIK6
Sep 17, 2016 02:31 PM
MDZ28
11
Sep 24, 2015 09:15 AM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
