Anyone know the bolt size for the M6 shifter bolts?
Old Jun 23, 2003 | 11:48 PM
98 SNAKE EATER's Avatar
Question Anyone know the bolt size for the M6 shifter bolts?
Long story short...
I was busy making a new switch panel a couple days ago and while I had the console out, I decided to reseal my shifter....
I had used yellow weather stripping before because it was all I had on me and although it sealed just fine, I wanted the piece of mind of using Black Silicone...
Anyhoo, I pulled the shifter and while torquing the bolts down with the new seal, I ended up stripping two of the case threads
That's what I get for swapping shifters 20 F'ng times
I have them snugged down to 20ft lbs. as is and the shifter feels solid, but I'd still like to go ahead and add Heli-Coils as soon as I can because the two that are stripped are on one side (driver)
Anyone know the actual thread size for these bolts so I can get the correct HCs?
Rick
Old Jun 24, 2003 | 05:50 AM
Guessing from your screen name that you are talking about a 98 F-Body, this belongs in "LS1 Tech"....... moving it there
Old Jun 24, 2003 | 05:25 PM
XTZ's Avatar
XTZ
8mm
Old Jun 25, 2003 | 11:43 PM
Thanx
I had a few others confirm this as well
Thing is, I went to AutoZone today and the closest they had were 8.3mm
They said it should work but I don't really have much faith in them... (especially when a kit will cost me $20 bux)
Gunna head out to Harbor Freight tools tomorrow and see if they have any in stock....
Rick
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
rcajun86
Jan 30, 2015 01:56 PM
