Dropping a cylinder?????
Old Jun 20, 2003 | 05:34 PM
whitehooptie's Avatar
I have a problem. It is on a 99 H/C camaro. When I drive "normal", under 25% throttle, the drives fine. When I go past 25%, the car is dropping a cylinder. Not sure which one. It threw a code (P0327) for a knock sensor, but as far as I know, the retard is programmed out. What are the chances of a coil going bad. Also it has MSD 8.5 wires on it that are not that old, NGK's in it that still have maybe 4000 miles on them. The car itself has 80k miles on it. Any help would be appreciated!
Brandon
Old Jun 20, 2003 | 07:29 PM
poxz's Avatar
Me Too!!
Hey I'm having the same problem in my 00 z28? My friends dad says a cylinder is mis firing and its easy to fix?? but I don't know if hes right
Old Jun 20, 2003 | 08:22 PM
I found my problem. Bad coil pack. Try that and good luck!
KYWes
Jun 14, 2022 06:52 AM
94Form
Jul 17, 2015 10:56 PM
Boss002
Jul 9, 2015 03:33 PM
NewsBot
Jul 8, 2015 06:47 PM
robyyzpapa
Jul 7, 2015 10:05 AM
