Quick, I need mechanical differences between the LT1 and LS1
Old Jun 16, 2003 | 04:54 AM
79TA_6.6's Avatar
Like it says, I need the mechanical differenced between the 2 engines, and also any reasons why american sports cars maybe better than japanease, and why pushrods arn't ancient types of engines.
Old Jun 16, 2003 | 05:45 AM
bigsteve7's Avatar
do a search for lt1 vs. ls1. this topic has come up a thousand times. I'm sure you can find everything you need to know in one of the older threads..
Old Jun 16, 2003 | 05:46 AM
79TA_6.6's Avatar
Tried that and I didn't come up with much actually, just general differences. I'm looking for mechanical differences, what is different internally and general.
Old Jun 16, 2003 | 06:54 AM
PhantomTA's Avatar
Moderator
everything except bore spacing and lifters.. nothing else is the same..
Old Jun 16, 2003 | 07:11 AM
79TA_6.6's Avatar
alright, well how is everything different.
Old Jun 16, 2003 | 08:15 AM
Erik 94TransAm's Avatar
A search would turn up more.
Everyone calls pushrods acient- overhead valves came out first, then pushrods. (this is early 1900s)
LS1 = Aluminum LT1 = Iron
LS1 uses 4 bar Fuel Pressure vs LT1s 3 bar - long story short, this helps atomization.
LS1 has even valve setup - i e i e i e i e vs LT1 has e i i e e i i e e means less chance for hot spots between 2 exhaust ports.
LS1 internals can handle more power stock.
LS1 has a composite manifold - less heat soak.
LS1 has tubular cast manifolds - similar to a shorty header.
LS1 CR = 10.1 :1 LT1 = 10.5:1
LS1 has better flowing heads stock w/ more potential for porting.
LS1 has 1.7:1 rockers
That's all i feel like typing.
mike
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
