Having a bitch of a time removing the oil pan...
Old Jun 21, 2003 | 03:56 AM
sleeperZragtop's Avatar
...I smacked my oil pan a couple of days ago and I started to remove the oil pan to be replaced...the tranny is dropped, flywheel is off and I still can't get any clearence to drop the pan...it looks like I'll have to lift the motor or drop the k-member...which I don't wanna do right now. The problem is the oil pump pickup is still deep in the pan, if I remove the oil pump, would the pick up thing come out as well? What do you think?
Old Jun 23, 2003 | 10:41 AM
Constrictor98TA's Avatar
Re: Having a bitch of a time removing the oil pan...
I've never heard of anyone trying to get the oil pan out without either dropping the k-member or pulling the whole engine. Im pretty sure that the oil pickup tube and windage tray would get in the way if you just tried to slide it backwards.
If you do figure out a way to do it, please let us know.
Old Jun 23, 2003 | 11:15 AM
Re: Re: Having a bitch of a time removing the oil pan...
Got it...you need to un-bolt the pick up tube...there is one bolt near the edge connected to the crank flange and one more bolt at the oil pump...near the front...very easy...you can drop the pick up tube with the pan...easy
You still have to drop the tranny to slide it back....that's the one thing I hate about the LS1 4L60E...no inspection cover
Old Jun 23, 2003 | 01:16 PM
Re: Re: Re: Having a bitch of a time removing the oil pan...
How do you get the oil pickup tube off without taking the timing chain cover off? Or did you take that off already?
If so, then you need to remove the front end of the engine, then the transmission, and it comes out? Hmm, still sounds like a ton of work!
Old Jun 23, 2003 | 03:09 PM
Re: Re: Re: Re: Having a bitch of a time removing the oil pan...
it still is a ton of work but I didn't remove any of the front..when you do a an oil pump swap you have to drop the pan to get to that front pick up bolt..you only needs an inch or two to get to those bolts...other easy but a pain..
Old Jun 23, 2003 | 06:18 PM
Camaro ChriSS's Avatar
Good to hear that worked out for you mike.
Old Jun 23, 2003 | 09:51 PM
stik6shift98's Avatar
Re: Re: Re: Re: Re: Having a bitch of a time removing the oil pan...
i did oil pump swap with engine out......easy....
then with the egine in omg....its a pain getting that bolt on.....without dropping kmember.....but i did it
Old Jun 23, 2003 | 10:55 PM
bunker's Avatar
You don't need to Mike, I thought you're taking the whole motor out??? Hmm......
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
jayblev95
Dec 1, 2014 06:55 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
JasonD
Jul 15, 2002 02:17 PM
