Weird bump stop
Old Jun 21, 2003 | 06:34 PM
BadAndy743's Avatar
Weird bump stop
I was trying to do the bump stop mod, but I kept getting a reading of 1.95 ohms. I tested the resistance from the blue wire to a ground with the tps plugged in. What the hell? I had the voltmeter set at 20k ohms. What am I doing wrong?
Bad Andy
Old Jun 21, 2003 | 07:04 PM
JaysZ's Avatar
Ohms? I know one method involves looking for a voltage level between ground and, I think, the blue wire- something approaching 4.6 or 4.7v, if I remember correctly.
Old Jun 23, 2003 | 10:39 AM
Constrictor98TA's Avatar
Yes, Jay is correctly. You need to set your meter to volts, not resistance.
The stock voltage rating at WOT is usually between 4.20-4.30v. The SES light will trip at 4.75v or higher. Try to get between 4.65-4.70v to be safe. I set mine at 4.66v with no problems.
Nayr
Mar 3, 2023 08:34 PM
Boss002
Jan 20, 2016 12:17 PM
generaldave
Sep 25, 2015 06:48 PM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 5, 2015 08:35 AM
