Installed Pro 5.0 Shifter...
Old Apr 17, 2004 | 10:24 AM
96Z28Guy's Avatar
I installed my pro 5.0 shifter last night into my car without the motor in the car....well after I put it in and i move the lil shifter deal back and forth it is really really rough. It like grinds or something. I want to know if this is normal? I pulled it out and thought maybe I had it on backwards, but it only goes on one way so I am positive it is on right. Maybe there is something special I had to do when putting it in? It was really simple (after i ripped the fu**ing dash out and unbolted like 15 bolts) and I thought I had it correct It is pissing me off. Oh and if anyone here has installed one, the part on the pro 5.0 that says "pro 5.0 shifter" or whatever is towards the front of my car, not the rear. Thanks!
-Ryan
Old Apr 17, 2004 | 12:10 PM
drewstealth's Avatar
yeah the PRO 5.0 part is gonna seem like it is on backwards when you look at it. Also when my car is off i can't go through the gears even if i push the clutch in. It will feel really rough untill you start the car then it should be smooth. So i would just wait untill you get ur motor back in then check it.
Old Apr 17, 2004 | 12:43 PM
93Z286Speed's Avatar
agreed, i have a hard time moving the shifter from gear to gear with the car off, once its running its a champ though
Old Apr 17, 2004 | 02:26 PM
96Z28Guy's Avatar
sadf
Thanks a lot for the input guys. I knew it wasnt on wrong, just wanted to double check.
-Ryan
Old Apr 19, 2004 | 06:21 AM
bad1LEz's Avatar
Make sure you lock-tite the allen head bolts that connect the stick to the shifter. Going 72 mph with the stick in your hand is no way to start a day...don't ask.
Old Apr 19, 2004 | 07:13 AM
magius231's Avatar
wouldn't you feel it getting loose long before it came off..?
Old Apr 19, 2004 | 07:42 AM
bad1LEz's Avatar
Yeh, the bolts rattling around was the first clue, however, that mentality of 'come on, just 10 more miles till I'm at work, and I'll fix it there instead of on the side of the interstate' kicked in. Trying to take the console apart and drive and hold the bolts in at the same time didn't work.
Old Apr 19, 2004 | 09:33 AM
Fast Caddie's Avatar
My stick kept coming loose the first month or so i had it..... then i got pissed and torqued the s*** out of the bolts one day and haven't had a problem since (about 6 months now). No Lock-tite though.
Old Apr 19, 2004 | 11:55 AM
ZZtop's Avatar
I found a piece of pipe about a footlong that fit nicely over the allen key and used that to torque the bolts. Havent had one come loose yet (4 months).
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
