Rear End Swap
Old Apr 14, 2004 | 11:30 AM
Thor39's Avatar
Rear End Swap
I have a qustion what is the differance in a 93 Z28 rear end and a 96 Trans Am Rear end would we have any problems just switching these out or is there a differance in the to?
Old Apr 14, 2004 | 01:02 PM
Dimensionally, they are identical and will swap with no problems. What you need to watch out for is the ABS sensor. Your 93 has a 3-channel ABS system, that has the sensor on the top of the diff housing. The 96 can be either just like that, or if it is from a car with traction control, it will have 2 sensors, one on the end of each axle housing, to support the 4-channel system used with ABS + traction control.
Old Apr 14, 2004 | 01:05 PM
LT1Squirrel's Avatar
also depending on tranny and option package you may end up with different gears which may help or hurt performance
Old Apr 14, 2004 | 03:00 PM
Thor39's Avatar
thank u that helps alot
Old Apr 14, 2004 | 05:24 PM
Thor39's Avatar
Is there an Diff. in the way the ABS systems hook up?
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
