Bad tranny or computer?
Old Apr 23, 2004 | 09:03 PM
95_RipperZ's Avatar
It started out last Oct. that my car just all of a sudden one day decided not to shift. I had the programming from PCM4Less in the car since June with no problems. Just cruising it would take to about 4.5k to shift from any gear. Totally sloppy. So I just put it away for the winter and said I'll deal with it in the spring.
Well, spring is here. I take the car out. Battery was completely disconnected all winter. Car shifts fine cruising around. So I think it is fixed. Take it to the track. Still shifting fine cruising. Then at WOT nothing. The 1-2 shift is ok sometimes but the 3-4 shift just isnt working. I even had the car reprogrammed to lower the shift points to 6k just so I dont have to rev to the moon to find out if it is shifting or not.
Does this sound like a tranny problem or a problem with my computer?
Oh ya, I jsut changed the tranny fluid and didnt find any trace that the tranny was busted. No shavings or burnt fluid, just the normal wear.
Magenta_Hearts
Mar 29, 2017 08:54 PM
jmadoll
May 27, 2015 07:13 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
