What is needed to correct the speedo on a 93 Formula?
Old Apr 19, 2004 | 10:11 AM
LT1Formulation's Avatar
I want to install 3.73 gears up from 2.73's. What needs to be changed to make the speedometer read correctly? Also, what brand gears should I use so I won't have problems with my ABS?
Old Apr 19, 2004 | 11:36 AM
IDOXLR8's Avatar
Ok since you have a series 2 carrier I would highly recommend going with Strange Gears. SLP sells a speedo calibration box to fix your speedo.
Old Apr 19, 2004 | 07:20 PM
There isn't a speedometer gear part number I could use to make the speedo correct? I am having DTS do my gear swap so they will have everything I need except that.
Old Apr 20, 2004 | 09:19 AM
IDOXLR8's Avatar
I am under the impression your car is a manual? If it is a auto (700R4) then I believe SLP sells a speedo gear to correct your speedometer.
Old Apr 20, 2004 | 10:06 AM
Nope, it's a 700R4. I'll give SLP a call this afternoon and find out if they have one in stock. Thanks!
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jul 4, 2005 05:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
