How much to switch to 3 series carrier?
Old Apr 13, 2004 | 09:58 PM
superkia8's Avatar
Just as it states, I am trying to get better gears than my 273s and dont know what the carrier is going to cost me?
Thanks,
Rich
Old Apr 14, 2004 | 07:16 AM
IDOXLR8's Avatar
IMO there is no need to go to a series 3 carrier unless your series 2 carrier is bad. Also Strange makes great aftermarket gears for series 2 carriers.
Old Apr 14, 2004 | 09:06 AM
race24x's Avatar
Cool I also have 2.73 gears and I didnt know someone made special gears for it. What wold you recommend for a daily driver I still want to get decent gas mileage just bolt ons like a cai and cat back maybe some 1.6 RR but no internals on motor. 3.42 3.73 ???
Old Apr 14, 2004 | 09:38 AM
Jay-Roll's Avatar
I thought GM had motive gears for both 2 series and 3 series carrier. I'd just stick with your 2 series and make sure you notify where your ordering from that the gears are for 2 series when you place the order. Also if your looking for better performance but still want to retain as much mpg as possible I'd go with 3.42's if you do frequent highway driving. If not go with 3.73's. Although each set of gears is gonna put your foot on the gas a lot more...trust me. The added fun will make mpg suffer for sure.
Old Apr 14, 2004 | 10:01 AM
race24x's Avatar
Thanks I will have to check about the series 2 gears and see what they offer I bought the ones for my truck from Jegs but I heard Richmond gears are quite loud my buddies Mustang has this issue it sounds like the rear end is going he had it done twice by a shop that builds alot of very good stuff.
Old Apr 14, 2004 | 10:08 AM
Jay-Roll's Avatar
Richmond are notorious for their loud whine from what I've heard. GM is supposed to be the best and also the most quiet. Good luck.
Old Apr 14, 2004 | 11:38 AM
IDOXLR8's Avatar
Is your car an M6? If so then you have a 3.36 first gear in your tranny. I would recommend going with a 3.73.
Old Apr 14, 2004 | 11:46 AM
race24x's Avatar
No I wish it was it is the Auto 4 speed
Old Apr 14, 2004 | 03:36 PM
94flamedta's Avatar
If you end up swapping i suggest Motives cheap and quiet. As for the 3 series carrier get hold of slp. They've got take out 3 series for about 100 bucks. As long as they have some left.
Old Apr 14, 2004 | 05:05 PM
Capn Pete's Avatar
You can definitely order gears (upto 4.10's or 4.56's I think ) for 2-series carriers. I know 'cause I had 3.73's in my car last year..............however, they were Richmond's, and whether it's common or not, they did whine really bad, and I had my factory 2.73's put back in (I may be playing with gears again this summer though).
I think for a daily-driver that is going to see some highway use, 3.42's are probably the best. My friend has them in his '96 T/A and he loves them. The 3.73's weren't the best for out on the highway IMO:blah:.
Old Apr 14, 2004 | 05:25 PM
superkia8's Avatar
Damn, just like that you guys helped me make my decision! 342s it will be and for a 2 series carrier.
Thanks for all the comments guys!
Old Apr 15, 2004 | 06:38 AM
race24x's Avatar
Same here I have 3.42's in my 80 Z its only a 3 speed but it does OK on the highway and still low enough to chirp second. How about 1 more question while I am here what is the deal with not being able to select first gear on the auto. Is there a way to change it? Does the tranny allow you to shift to first if you change the shifter or is it a mute point anyway? I do not want to swap trannies in the car.
Old Apr 15, 2004 | 10:24 AM
superkia8's Avatar
I think there is a way but I couldnt figure it out myself? Something with lifting the consle and getting rid of a rubber stoper or something? Search some posts and you will find it. Mine only has the 2nd gear option also!
Old Apr 15, 2004 | 01:32 PM
Jay-Roll's Avatar
In auto cars that came stock with 2.73's we weren't able to select 1st gear, but it is available. Just lift the little rectangular console up that fits around the shifter. In case your not sure what I'm talking about it's about 6 inches wide by about 10 inches long and houses the gear selection information on it. Then on the shifter linkage somewhere(can't remember where but you'll know when you see it) there is a little black plastic square about the size of a jolly rancher. Maybe a little smaller, but you get the idea. Anyway all you need to do is remove that. It's basically just a stop tab and that's the only purpose it serves. I think I ended up chopping mine off with some wire snips, but whatever works for you. Once you do that if you wanna sand it down or anything to clean it up go for it, but as long as you can slide past it that's all that matters. Put the console top back on and tada, you now have first gear. It obviously won't show up on the gear selection thing, but you can shift right back past it into 1st. This is probably a 5 minute job if you've never done it before. Good luck.
Old Apr 15, 2004 | 01:40 PM
race24x's Avatar
Thanks for the info now that one is a really easy upgrade
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
