Is this my carrier?
Old Apr 10, 2004 | 05:04 PM
DAC350's Avatar
Is this my carrier?
OK the rear end sounds fine under normal driving. But if I engage the line lock and do a small burnout out the rear make a repetitive popping sound. Also, sometimes my limited slip won't even engage (one wheel burnout), but when it does it make that noise. My question is could this be a problem with anything other than the carrier? I recently changed the fluid and added the GM additive and it didn't help. Thanks.
Old Apr 10, 2004 | 06:42 PM
DAC350's Avatar
If it only happens when limited slip kicks on it has to be the carrier right?
Old Apr 10, 2004 | 06:44 PM
Jason Dove's Avatar
If you turn on the line lock and only 1 wheel spins sometimes, your posi is on the way out. So yeah, I think your carrier is shot.
Old Apr 10, 2004 | 06:45 PM
DAC350's Avatar
I am currently running a slp t/o, what other carrier would you suggest?
Old Apr 10, 2004 | 07:09 PM
Jason Dove's Avatar
One attached to a 12 bolt or a 9 inch.
I used to run the Auburn Pro with the RaTech solid pinion spacer on my 10 bolt. Don't know how much they go for now.
The SLP one is cheap though, so your call.
Old Apr 10, 2004 | 08:40 PM
DAC350's Avatar
Does slp still offer the t/o? I can't find it on their site? Thanks.
blkss01
Mar 29, 2003 02:36 AM
DTABFORMULA
Feb 28, 2003 04:56 AM
SnkEatr
Feb 24, 2003 11:30 AM
sideways_Into_3rd
Feb 16, 2003 12:24 PM
TransAm_Impostr
V6 Tech
Feb 15, 2003 07:15 AM
