Abs Sensor
Old Apr 15, 2004 | 09:44 AM
slp223's Avatar
Abs Sensor
I have a few question about the abs in the rear. I just blew up my 12 bolt and when it broke the abs inop light came one i have had the rear rebuilt. and the abs inop light is still on. Could the sensor been cloged or damaged with metal chuncks? is it how do you have to align the abs ring with the sensor. also what is a part number for that sensor? thank you for any help.
Old Apr 15, 2004 | 10:51 AM
IDOXLR8's Avatar
I am assuming your reluctor gear is on your carrier rather than on your axles. I would examine the reluctor gear for any damage done to the teeth.
Old Apr 15, 2004 | 11:14 AM
slp223's Avatar
the ring is on the carrier and there is nother that looks wrong with it.
Old Apr 15, 2004 | 11:38 AM
What brand 12-bolt... I think the Moser uses the stock sensor, and I know the Strange uses its own type sensor. Did you check the sensor for damage, or excessive buildup of metal particles? Did you check the wiring? If its a Strange, did you reset the clearance to the reluctor ring?
Old Apr 15, 2004 | 12:05 PM
slp223's Avatar
it is a ktre which i now dts. nothing changed with the wiring from when it worked. the sensor did have metal chuncks in it but i whiped them all out. how do you resed the clearance for the ring?
Old Apr 15, 2004 | 03:56 PM
Depends what your sensor looks like. The stock sensor isn't adjustable. Strange uses a sensor that threads into a cap on the top of the pumpkin.... you adjust the sensor to reluctor ring clearance to get the sensor to function correctly. I have no idea what kind of sensor the KTRE has on it.
14
Aug 11, 2015 12:03 PM
realistyc
Jul 28, 2015 07:32 PM
Noct
Jul 14, 2015 01:18 AM
CARiD
Jul 7, 2015 08:19 AM
