Recomendation on where to get Moser12?
Old Apr 24, 2004 | 08:33 PM
"White Knight"'s Avatar
Alright it's time to sell the farm and get the 12-bolt. I wondered if you guys could reffer me to some place to buy one......good deal and good service. I was thinking of buying through thunderracing.com, but i wondered what you guys thought.
I also need to know what ABS i have.....i am pretty sure it's 3channel right? It's a 94. Also should i get bigger wheel studs or get stock size?
Old Apr 24, 2004 | 09:39 PM
12sec97Z28's Avatar
Thunder Racing. They've always been extremely awesome to me and actually called me back to let me know my debit card had a $2000 a day limit and agreed to take half one day and half the next. Plus, they're running a $50 off every Moser 12 bolt right now.
ABS- 3 channel if no traction control, 4 channel if you do have traction control.
Wheel studs- I could be wrong here, but I think the longer wheel studs will cause problems with the stock style wheels fitting... at least the center caps.
I got every option available since you don't make a purchase like this very often and stuck with stock size studs. Love it, and it was not hard to change it out, just took a few friends to help manhandle it.
Old Apr 25, 2004 | 07:56 AM
97FormulaWS-6's Avatar
Tbyrne is running a GP on the Strange Units right now....
They're a plug-n-play and require no modifications to bolt in (except replacing the u-joint), plus they come fully-assemblyed and dyno-tested.
I'm 99% sure you have to shorten the DS to run the Moser, plus replace the Sway-bar mounts due to the larger axle tubes.
Old Apr 25, 2004 | 08:30 AM
bowtiepwr's Avatar
>Igot mine (Strange 12 bolt) through www.Tbyrne.com and it was plug and play ... make sure you get the gears you want and paint it prior to install (Rustolium is pretty good) .
Old Apr 25, 2004 | 10:05 AM
SantaCruz163's Avatar
BMR's website sells Moser 12 bolts and 9"s
Old Apr 25, 2004 | 07:37 PM
simple's Avatar
used, i got mine for $1500 FULLY loaded
Old Apr 25, 2004 | 08:29 PM
The swaybar thing isn't a problem......going to do the Drag sway bar while i'm at it.
I haven't heard about shortening the Driveshaft though Anymore info?
Old Apr 25, 2004 | 09:06 PM
I guess they don't come painted either.......so what type of paint should i use?
Old Apr 26, 2004 | 11:09 AM
search in this forum for "Moser Driveshaft" there a quite a few posts on it...
Sauced
Apr 12, 2015 10:18 AM
97 RedSS
Feb 11, 2003 02:33 AM
megathumpzilla
Dec 16, 2002 10:53 AM
2k2z28
Nov 9, 2002 05:13 PM
Dave89IROC
Oct 15, 2002 08:12 PM
