rear end additive?
I have always been told that you should add it reguardless of what type of oil you put in. Plus it is not very much, when you look at the possible risk of replacing the posi(in the long run if its missing causes the posi to "burn-up").
Spend the $4 or $5 it costs. If you don't need it, you'll have some extra oil in your differential. If you do need it, you won't have to worry about it. It's better than listening to that groaning sound from the rear end!
oldschool
Feb 9, 2016 09:21 PM
