4.10's in A4
Old Apr 23, 2004 | 04:52 AM
iiiezekieliii's Avatar
4.10's in A4
Currently, I have a stock 3.23 rearend... I was wondering if 4.10's would be worth the money.
Its a daily driver, about 1000 miles a month. I would say about 80% of those miles are on the street. I would just like to have better acceleration and dont care too much about sacrificing my top-speed, I really dont plan on ever taking it over 120mph.
I have tried searching to no avail, but most of the info is for m6's.
If i do go for 4.10's I need to get the 3-series gears because i have a 3 series carrier right? What else do i need aside from the gears? How long should the install take?
Would the tranny life be decreased by running this gear?
any input would be greatly appreciated, thanks
Old Apr 23, 2004 | 07:51 PM
speed_demon24's Avatar
Unless you drive with drag radials all you will be doing is spinning with 4.10's. I just got my 3.73's in today, but it still needs another heatcycle or 2 before I can get on it, but I can already tell there is a huge difference.
Old Apr 24, 2004 | 04:00 PM
raceryan's Avatar
You may want to go with 3.73. I had 4.10's and it tachs real high & helps to kill MPG too. You will have a definate problem with getting traction with 4.10's. ANd when you finally get it to hook up, you'll break the stock 10 bolt rear. I had the same problems. Broke the rear, said forget it and put in 3.73's.
Old Apr 24, 2004 | 04:59 PM
steve10358's Avatar
3rd Gen Tech Moderator
As far as I'm concerned, if you drive a car like this- who cares about MPG? I love my 4.10's in my A4 car. My car only spins because my Drag radials are 2 years old and are not sticky anymore.
Old Apr 24, 2004 | 05:26 PM
whattabout with a 2800 stall?
Old Apr 26, 2004 | 07:31 AM
steve10358's Avatar
Choose your gears based on the tires you wanna run at the track. I use 28" tall ones with mine, when I'm not on my 17x11's.
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
colts0455
Jul 24, 2015 04:51 PM
