CC306 4.10's 4L60E ,4.10's too much?
Old Apr 18, 2004 | 10:49 AM
LT4orbust's Avatar
My car is mostly stock,will be putting in the CC306 , headers,52 or 58mm TB, 3200 stall. I have most of the parts, will the 4.10 rear gear be too much for somebody that's not too picky about MPG , I've rear through a lot of the forums here and didn't really find a good answer,a lot of specs though. I really want to get my 1/4 mile time down but don't want to kill the top end ....some lose of top end is ok, I have 3.42's , the question is 3.73's ,4.10's or stay with the 3.42 with the mods that will be added
Old Apr 18, 2004 | 09:09 PM
xxsaint69x's Avatar
go with 3.73...4.11s will be too much in my opinion. You will lose too much top end with an auto.
Old Apr 18, 2004 | 09:56 PM
my94blackz's Avatar
Go with the 4.10's.
Old Apr 18, 2004 | 10:34 PM
LT4orbust's Avatar
4.10's are what i was thinking,i've seen such small differences between the 323 and 373 , so i think that goingfrom the 342 to 4.10 shouldn't be too bad a jump considering the gearing in the trans
Old Apr 19, 2004 | 05:24 PM
Tekprodave's Avatar
Maybe but you could go with a 28" tire if it is.
Old Apr 19, 2004 | 06:25 PM
LT4orbust's Avatar
Yeah, i didn't really think of compensating that way!
Old Apr 19, 2004 | 07:55 PM
Pro Built Automatics's Avatar
If you are serious about getting good 60 foot times, then the 4.10's with taller sticky tires will do the job, (suspension work will help also). Remember, the more of a fore & aft "footprint" you have, will help in acceleration.
Old Apr 19, 2004 | 08:09 PM
LT4orbust's Avatar
Question
I know what you mean by footprint, but the fore and aft part is???
Old Apr 19, 2004 | 08:12 PM
LT4orbust's Avatar
Do you mean front and rear contact of footprint as compared to how wide a print. larger fore and aft due to larger diameter tire? but not nessesarily wider
Old Apr 20, 2004 | 04:59 PM
speed_demon24's Avatar
Chances are you will hit 4th before the end of the 1/4 too, which might hurt you a little bit at the top of the track.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Z Power
Sep 19, 2015 11:19 PM
