ExtremeChassis Ford 8.8" rear end
Old Apr 20, 2004 | 08:48 AM
Grease's Avatar
Question ExtremeChassis Ford 8.8" rear end
Has anyone had experience with these people?
www.extremechassis.com
I can get a Ford 8.8" rear end that already has a TA girdle on it for free so I won't have to worry about a core charge. With the Eaton posi it will cost 1730$ which is alot cheaper than any 12-bolt or Ford 9" costs, before adding on all the options. I know the Ford 8.8" is a very strong rear end but before I go spending the money I'd like to know if anyone has seen or heard about the quality of their work.
Waswa
Old Apr 20, 2004 | 09:17 AM
IDOXLR8's Avatar
My question is not why spend another 300 and get a 12 bolt? If you are spending that much you might as well get the best you can for your dollar.
Old Apr 20, 2004 | 01:37 PM
flyinZ's Avatar
I've heard good things about them, but last time I heard, they were on back order with a few things..
Old Apr 20, 2004 | 03:26 PM
Grease's Avatar
Actually its a 500$ difference if you include a TA girdle and ABS. Thats 500$ I can put elsewhere in the car. Really I mind end up putting in a Moser Ford 9", I'm still considering my options. I don't see how the 8.75" 12-bolt is any stronger than the Ford 8.8", it comes with Moser axles and an Eaton posi, I just question their quality considering all the welding they do on the diff housing for the torque arm bracket.
Old Apr 20, 2004 | 04:19 PM
chpmnsws6's Avatar
because an 8.8 is stronger, lighter, and more effiecent than a 12 bolt. a 12 bolt is 8.7
Old Apr 20, 2004 | 10:44 PM
brain's Avatar
I don't think a 9" is neccessary unless you are running VERY low 9s. There are plenty of people running mid - high 9s with 8.8s in mustangs. I know of more than a few guys running low 9s with the stock traction lock diff too.
Old Apr 21, 2004 | 07:22 PM
firepheasent's Avatar
I know of an 8.20 mustang running an 8.8!
Old Apr 23, 2004 | 01:40 AM
1BAD86Z's Avatar
custom assemblies
when welding cast iron to steel you are playing with fire, yeah they really lay it on but adventually after abusing it the welds will crack.
so that said i am doing ford 9" custom assemblies for 4 chanel abs for less than what shops charge. i have no shop over head, i work out of my garage but dont take that the wroug way, i used to work at DTS in warren michigan for 6 years, but now i have moved on the better things but am still state cert. and do gear installs in my driveway. e-mail me at www.skoresky@yahoo.com for further info.
Old May 20, 2004 | 07:30 PM
87roc_t56's Avatar
Welding cast is indeed tricky... but cracks do not mysteriously appear after time or abuse with cast they will happen within hours of the welding. Its the graphite expulsion that causes problems when welding cast but with the proper equipment and technique it works excellent.
Whats not to gain by using an 8.8? Here are just a few obvious plusses;
1. WAY lighter than a 9 inch
2. More effecient than a 9 inch or 12 bolt=more RWHP
3. They run much quieter than a 9 inch or twelve bolt.
4. Parts are readilly available and very affordable
5. They are just as strong as a 12 bolt maybe stronger
- 12 bolt carriers have been known to break
6. You can get them as a bolt in with no hassles even the stock sway bar
will fit unlike a 9" or 12 bolt
Don't knock what you haven't tried... you may be missing out on something great.
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
