rearend noises
Old Apr 9, 2004 | 08:37 AM
shming123's Avatar
Question rearend noises
on the car that i'm buying tomorrow, the guy put a 4.10 rearend in, and there is a wierd noise coming from it and he says it is a result of that. He said its a Richmond rearend. The noise is like a humming, sort of, or maybe like a howl..it isn't loud, its just there...i was just wondering if this was normal... And also, i am going to put new tranny fluid in and new oil in the rear end... Whats the best oil i can buy for each? Thanks.
Old Apr 9, 2004 | 12:40 PM
Black_95Formula's Avatar
If the whine isn't too loud then I would say it is normal. Only the best professionals can install gears perfectly with no whine. I had a shop install a set of Jegs 3.73 gears and they whine around 60-ish in sixth gear only.
The whine is caused by a slight missalignment which is very hard to correct unless like I said a pro does the work. However, changing the rearend oil may solve the problem or at the least make it better. Hope this helps.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
mrwz28
Jul 8, 2015 09:11 PM
colts0455
Jul 7, 2015 07:19 PM
