Will my rearend hold?
Old Apr 24, 2004 | 02:40 PM
mooleyz28's Avatar
I have hooker longtubes, ORYP, Borla Catback, 4.10 gears on the stock 10 bolt rearend, lid, ls6 intake manifold, star stage 3 clutch, and a trex cam. I havent got it dyno tuned or anything yet. But im wondering if my rearend will hold. Should i go with a girdle or should i just wait another 2 months to drive my car and save up for a 12bolt or a 9" rearend? Anyone know if it will hold or not? If not what should i do? By the way the car is an m6.
Thanks for the help,
John Melamed
Old Apr 24, 2004 | 04:58 PM
8850's Avatar
It will hold until you launch hard the first time with sticky tires.
Seriously the 4:10 ratio is a weak combination. The pinion is too small. It will take teeth off. Better saved up for that 12 bolt or a 9".
Old Apr 24, 2004 | 05:32 PM
robb4964's Avatar
hey 8850.....What mods do you have on your car ? I am vry curious . Nice times man . ..And mooley ...Your rear will last as long as you dont launch it hard .
Old Apr 24, 2004 | 05:38 PM
8850's Avatar
I have heads/cam, Pace Setter headers with cutout, PI 3600 stall, lid and a few light weight mods. My rear had taken a 1.496 launch but I have a 3.23 gear. It has 13 teeth on the pinion as compared to your 10 teeth.
http://www.mustangmods.com/data/440/camaro_1.607_60.jpg
Old Apr 24, 2004 | 11:02 PM
96SFLZ's Avatar
It's just a matter of time. Even if you launch easy...if you shift good (quickly) you could easily break it on the 1-2 shift. I know people who have done just that and that's what I'm worried about (with my car)...enough so that I won't take my car back to the track until I have a 12-bolt.
So...save up for the 12-bolt.
Old Apr 25, 2004 | 02:09 AM
94ZRiCeKiLr's Avatar
with your setup...i can almost guarantee that 10-bolt is not going to hold for even one good launch. sorry.
Old Apr 25, 2004 | 11:28 AM
ULTIMTEORANGESS's Avatar
itll hold up for awhile.well,it should.
just run on it till it breaks then replace or repair it.
some people have had them hold up awhile.others havent.
Old Apr 26, 2004 | 05:34 PM
redzsmoked212's Avatar
dude as long as you keep street tires on your car it will hold up cause you will never get traction with them. putting on dr's with all those mods you got and having a manual that rear-end is shot. i put 4.10 in my 99 z-28 auto with dr's but didnt modify it too much just lm exhaust free cold air,mafs smooth bellows and my car is pullin high 12's all day long and the rear end is holdin like a champ.cant really do too much more or the rear will be gone.
Old Apr 26, 2004 | 05:43 PM
dnz28's Avatar
youll be fine, just dont get to crazy with the rpms when you launch. just stay away from et streets. you should even be fine on some drag radials.
Old Apr 26, 2004 | 07:09 PM
rpm4lalo's Avatar
I have broken three ring and pinions in my 10 bolt. Have killed one posi. Have destroyed one pinion bearing. And the rear end is whining so loud right now that I can hear it easily over my true duals and bullet mufflers.
My point is, I have done all this damage with drag radials.
Old May 9, 2004 | 09:32 PM
mrr23's Avatar
mr mooley28 - need to answer my pm about still not receiving the money yet.
Old Jun 1, 2004 | 06:16 PM
mrr23's Avatar
as of today mooleyz28 has paid me.
Old Jun 1, 2004 | 07:09 PM
i just recently added a MAC girdle and stud kit.i highly recommend this part.its definitely gives these rears needed extra strength.
Old Jun 21, 2004 | 05:12 PM
eric9c1's Avatar
Are the LS1 rear ends like 7.5" or something?
I have a stock GM 10bolt 8.5" (94 Caprice) and it's taken plenty of hard sticky tire launches, and my car weighs more. Is the 1" in rearend size really that much stronger?
The fastest it's seen is 12 second runs, slowest is 15, and about 150 actual track runs inbetween.
Posi is burned out now though Works when it feels like it (about 40% of the time)
383 going in though, I don't figure it to last through that.
Old Jun 21, 2004 | 08:38 PM
yeah that 1 inch will definetly make that rear end much stronger
