Any Suggestion?
Old Jul 21, 2002 | 11:11 PM
86IrocCamaro's Avatar
Post Any Suggestion?
I have around 450HP in my 86 Iroc but the engine is gettin sluggish on me so I think im going to start a new project with another 350 4 bolt main. My plains are for a 500+HP 350 engine and yes its gonna be a street legal car thats gonna run off of 93 pump gas. So far I'm going to get a set of alum heads that flow up to atleast 320cfm, a 302 comp roller cam, roller lifters, atleast a 12.5:1 CR, 1.6 alum roller rockers, bore it .30 over, a holley dual plane intake, holley 750DP carb, K&N Filter, HEI Distrib. I'm open to any suggestions that you might have. I'm going on a budget for 4-5k. Im sure i can do this since its a Chevy
86 Iroc Z28
350 4 bolt main .60 over
11.5:1 CR
280 Comp Cam
2.02 P&P Heads
Eldebrock Intake
Holley 600 carb
Holley FreFlow Air Filter
4:11 Gears
Th350 Transmission
Old Jul 21, 2002 | 11:31 PM
Stephen 87 IROC's Avatar
Post
Change your valve springs. I'd say they're shot. How old are they? Original are 16 years now.
A 750 is a little small for 500 HP and I really doubt you're getting 450 HP with a 600 carb.
A 500hp 350 on pump gas with 12.5:1 and street legal? Keep planning.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Old Jul 21, 2002 | 11:39 PM
Z_Ghost's Avatar
Post
Do you work for Hot Rod Magazine?
Old Jul 21, 2002 | 11:47 PM
Post
the engine is about 6 years old itself and its been ragged quite a bit, i street race every weekend. yes 450hp on a holley 600, i put a 750DP on it and it just bogged out alot. and no i dont work for hotrod magizine, lol
86 Iroc Z28
11.5:1 CR
280 Comp Cam
2.02 P&P Heads
Eldebrock Intake
Holley 600 carb
4:11 Gears
Th350 Transmission
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
