Traction Problems
Old Jul 12, 2002 | 12:54 PM
speedfreak85's Avatar
Post Traction Problems
I have an 88 RS with a moderately built 350, around 400 hp, and a 700R4 with a shift kit. Now when I punch the gas it spins off the line, and it almost goes sideways going into 2nd and 3rd gear. I'm sure if i had more traction I could get much better track times. The tires on it now are stock, so I'm asking if there's anything i can do to increase traction. Maybe offset rims w/ wider tires? This is a street car too so i don't want to run slicks. Any suggestions appreciated.
Old Jul 12, 2002 | 01:00 PM
irocz383's Avatar
Post
Your looking at spending a lot of cash...
Adjustable torque arm, LCA's, lower the car, LCA relocation brackets, and Adjustable panhard rod.
You'll also need a good set of sticky tires. I'm using Micheline pilots and they are great. Way better than my previous BFG's.
Old Jul 12, 2002 | 10:59 PM
BergerSS435's Avatar
Post
ohhhhhhh, just quit dickin around and get some E.T Streets!!!
Kirk
**Wanted** 4th gen F-body. good exterior condition ,LT1,6spd, preferably t-tops, under $8,000 Or a clean 3rd gen 350 TPI. ChirpthirdLS1@aol.com
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
Teal94V-6
Aug 31, 2002 09:21 PM
jp2002ls1
Jul 22, 2002 04:18 PM
