starter????
Old Jul 13, 2002 | 04:11 AM
nightrider's Avatar
Post starter????
i'm in the process of changing my starter on my car. if anyone has done this, will the started be able to come out with the lower end of the exhust manifold in the way? and how long did it take you, because a few of the bolts are mothers.
'88 WS6 formula red L98 tpi, 3.27 rear no mods yet
Old Jul 13, 2002 | 07:57 AM
angel71rs's Avatar
Post
I had to drop the y pipe to get starter out. And yes, it was a mother.
Old Jul 13, 2002 | 01:24 PM
PonyEtrZ28's Avatar
Post
yup, the way to do it is drop the y-pipe, but i wasnt about to do that. so i some how
removed the solinoid (sorry about the spelling) from the starter and it pulled right out. it was not a fun job.
but it was easier than dropping my gas tank thats for sure.
good luck
shaun
Old Jul 13, 2002 | 02:05 PM
nightrider's Avatar
Post
actually, just now, i got it out without droping the y-pipe. it was a tight fit, but it came. it just took alittle twisting, but for the most part, came out pretty easily.
later
Old Jul 13, 2002 | 11:08 PM
firechicken_3's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by nightrider:
later
</font>
that is so not fair, i had to drop my y-pipe too
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
Old Jul 14, 2002 | 11:52 AM
Randy92Z's Avatar
Post
A LT1 starter is a smaller unit and has more power (turns over a 10.5 LT1) next time you need a starter get one. It just bolts in. At least mine did, and you wont have to drop your Y-pipe again.
Convertible W/L98, Mini-ram, ZZ9 cam, TPIS 52mm TB, Comp Cams 1.52/1.6 steel roler rockers, Trick flow 23* heads, K&N's with chopped airboxes, Edelbrock ceramic TES, Flowmaster cat-back, Dynomax high flow converter, Accel 300+ ignition, Fastchips custom chip, Taylor pro 409 wires, March underdrive pulleys, MAC subframe connectors, Lakewood LCA & Adj. panhard rod, SLP 2500 stall, 3.42 rear gear, 90 Corvette rims, White face gagues, and NOS!
[This message has been edited by Randy92Z (edited July 14, 2002).]
Old Jul 14, 2002 | 06:28 PM
91 Redd Sledd's Avatar
Post
When I put the lt1 starter in my car I had to lengthen a few of the wires no big deal. They are lighter,provide more torque,and sound a helluva lot cooler.
Old Jul 14, 2002 | 07:28 PM
1fastformula's Avatar
Thumbs up
pulling the starter out is easy....Putting it back in is a B!@ch!!!!!! Laying on your back with a 20+ lb. weight in your hand above your head......trying to fenaygle( sounds good) the beast back into the hole.
It can be done( I have done it three times without dropping exahust) with patience and alot of arm strength.
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/owne...php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula
Old Jul 15, 2002 | 01:17 PM
Ucantcme57's Avatar
Post
You can get it out without removing the y-pipe. I had a 92 S-10 with a vortech 4600. I had to put a starter in it. It is a pain hope your forearms are strong, like someone else said. It's like laying on your back and waving at the sky for half an hour with a 20lb. weight in your one hand. don't get to upset, I kinda layed mine pararell with the car and slid it in and giggled it and so on till you get in in there. the best way to figure it out. get all the wires disconnected and just get it out. and watch how you have to turn it and slide it to get it back in.
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
