Will platinum plugs burn out faster????
If i put platinum plugs in my 305 TPI will they burn out faster than regular plugs? Also, are bosch platinums +4 better than Rapidfires? Thanks
<font face="Verdana, Arial" size="2">Originally posted by Kodiak2727:
If i put platinum plugs in my 305 TPI will they burn out faster than regular plugs? Also, are bosch platinums +4 better than Rapidfires? Thanks</font>
Don't waste your time and money with the +4 things. the only thing your gonna get out of the +4's are longevity, it's basically 4 plugs in one. Electric current does not go to all four prongs at the same time, it goes to the one with the least resistance. As time goes on, and that one gets worn, a different prong will have less resistance and the spark will travel there instead, and so on and so on...
I've got a friend with a fox 5.0hat had those things, and he had terrible idle surges. He ditched them for some good ole autolites and never had the problem again. Just food for thought.
If you absolutely feel the need for platnums just go with a set of delco's. Its all your ever gonna need.
Eric
Eric
Don't waste your money on either. Instead, buy the factory AC Delco's and modify em, like this-
spark plug
They might burn up a little faster, but they only cost a buck a piece, so no harm done. Dyno tested by NUMEROUS companies/magazines. Good for 5-7 HP on a stock run of the mill smogger 350. Maybe more with a good coil.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner w/K&N, SLP 1 3/4, Catco cat, Hooker cat-back, built 700r4 w/ Darrell Young 2400 stall TC, Jet stage 2 chip, SSM subframes, Lakewood LCA's, Powertrax locker w/stock 3.23's, Centerline Auto Drag's
spark plug
Just get some ac-delco's or some champions make sure they are the right length inside the chamber and that they are gapped. +4 foul out really quickly, espically if your playing with the timing to get it to run right.. I went through four sets of plugs before I got my car to run right. Never using +4's or the reg bosch's ever again.
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Mods;
ntimad8.cz28.com
