who makes front lower control arms for 3rd gens?
Old Jul 11, 2002 | 07:50 PM
IrocSS85's Avatar
Post who makes front lower control arms for 3rd gens?
i need balljoints, but dont see a point in spendng even $50 to buy them and press them in cause the bushings are prolly shot and they are rusty as hell. I can get new stock IRoc ones for $130 ea. but would rather get some lighter aftermarket ones if anyone makes them.
any ideas? thanks chris
1985 Iroc Z, (parting out, email for parts)
1986 Iroc Z
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires. mid 13's for now. lots to play w/still
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Jul 11, 2002 | 08:25 PM
92BLKL98's Avatar
Post
I just did a complete suspension overhaul front and rear. You can buy 2 ball joints and a set of PST polygraphite bushings for ~ $100.00. You can get the bushings and ball joints pressed in for about $50.00. It is a PITA to remove/install the old bushings and ball joints if you don't have access to a press. The end result is amazing and you will not have spent $130.00 for each control arm.
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods Random Technology cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
[This message has been edited by 92BLKL98 (edited July 11, 2002).]
Old Jul 11, 2002 | 08:44 PM
Bad 91z's Avatar
Post
Call PA racing, thats where i got my tubular k-member and a-arms.(812) 392-3431.
Marty
91 Z28 4L60, electric red, 355. JE 11.1 flat tops, LT-1 rods, L-98 crank. Ported trick-flows by GTP, cc 306 grind, 1.6 chromemoly rr's, LT-1 intake fabricated for L-98. Tubular k-member,a-arms,manual rack-and-pinion,coil-overs,koni spa-1's. Ford 9" w/3.89's and spool. and still more to come.
'89 Mustang GT. just got it. only weight reduction mods so far.
'99 Neon R/T daily driver
Old Jul 11, 2002 | 09:10 PM
91RS5speed's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Bad 91z:
Marty
</font>
How much were they if u dont mind?
91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Jul 12, 2002 | 05:56 AM
IrocSS85's Avatar
Post
Marty
</font>
thanks marty. I'll give them a call. I wonder if the a arms sill work w/stock front kmember? prolly wont work w/coil springs either. I'll still call to see how much they are and to see if they will fit stock stuff.
chris
If I do end up redoing the stock arms, then I'll prolly sandblast them and have them powder coated cause no way am I puting back on rusty arms after all this work.
Old Jul 12, 2002 | 06:28 AM
Scott_92RS's Avatar
Post
www.paracing.net
Old Jul 13, 2002 | 02:30 PM
kandied91z's Avatar
Post
i would just refinish them......if you can powdercoat yourself go for it. otherwise just paint them nice, powdercoating and a good paint job work just as well. for the price you'll save instead the coil-overs and the tubular setup you'll be much happier.
Old Jul 14, 2002 | 01:25 AM
Bad 91z's Avatar
Post
Not sure about price, I got the k-member, a-arms, coil-overs, and manual rack for a little over a grand. Didnt even look at the reciept, just threw it away.
Marty
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
