GUYS I NEED HELP ASAP.........
Old Jul 26, 2002 | 06:07 PM
Wallace1990's Avatar
Post GUYS I NEED HELP ASAP.........
Hi, i am trying to install a hypertech chip in my 1988 Trans Am GTA 305 TPI and i cant find the computer, i took the bottom of the passanger side dash off and i found a silver box, but all i see is a printed circut inside. What am i doing wrong? Thanks
Old Jul 26, 2002 | 06:34 PM
STAYBG's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Wallace1990:
Hi, i am trying to install a hypertech chip in my 1988 Trans Am GTA 305 TPI and i cant find the computer, i took the bottom of the passanger side dash off and i found a silver box, but all i see is a printed circut inside. What am i doing wrong? Thanks</font>
THAT SILVER BOX IS THE COMPUTER,TAKE THE TEO BOLTS HOLDING IT UP AND IT WILL COME DOWN,THEN UNSCREW THE TWO SCREWS THAT HOLD THE PLATE ON THEN YOU WILL FIND THE CHIP
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
3' 2 chamber flowmaster cat-back system.
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
ALL AROUND SUSPENSION KIT
Old Jul 26, 2002 | 06:52 PM
Post
Stay, thanks for the reply. Heres the deal, i droped the silver box but there is not a cover plate with two screws on the silver box. I opened the silver box and its a printed circut board with resistors and other **** on it. But there is not a cover plate on this silver box, i assure you. Am i looking at the wrong box here? Is it different on the Trans Am? Thanks for the help!
Old Jul 26, 2002 | 09:46 PM
phoenix916's Avatar
Post
How big is the box you are looking at? I cant' think of anything else silver under there. I will look tomorow.
Old Jul 26, 2002 | 09:52 PM
Post
Phoenix, thanks for replying, the silver box is about 5 inches by 5 inches. Like i said there is no cover plate anywhere on this thing. Thanks
Old Jul 26, 2002 | 10:01 PM
phoenix916's Avatar
Post
OK. I just looked and there is no other box other than the computer. I looked at a 92 bird and can look at a 86 TA SE if you want but I bet it is the same. There should be a little cover on the side about 2" x 3" with two bolts thats where the chip is. Also Hypertech didn't do anything for me.
Old Jul 26, 2002 | 10:26 PM
aklim's Avatar
Post
Phoenix, thanks for replying, the silver box is about 5 inches by 5 inches. Like i said there is no cover plate anywhere on this thing. Thanks</font>
5 X 5 is a little small, isn't it? I thought it was around 8.5 X 6. X 1.75. At least mine is.
Old Jul 26, 2002 | 10:29 PM
Post
Yes it does seem small, but thats the only silver box there. Also, how many plugins do you have running to your computer, on this one there is only one plugin running into it.
Old Jul 26, 2002 | 10:48 PM
phoenix916's Avatar
Post
2 multiwired plugs.
Old Jul 26, 2002 | 10:53 PM
Thumbs down
man whats going on, why is mine so different??
Old Jul 27, 2002 | 02:24 PM
RedIrocZ-28's Avatar
Post
Wallace, what are the numbers on the ECM? The number should end in 165. If not you are looking at the wrong thing OR someone did a swap of some sort. Report the #'s back to us if you would.
Old Jul 27, 2002 | 03:03 PM
aklim's Avatar
Post
I don't know but I disconnected my ECM the other day and saw 3 sets of multi-wired plugs and I have a 91 Firebird Formula
Old Jul 27, 2002 | 03:19 PM
Post
Hi guys, i found the computer this morning, its back up underneath of the dash, its bolted in with the multiwired plugins you guys spoke of. It looks like i will have to rip a good portion of the dash off, i dont know if i want to do that. Also, lets say i didnt put the chip in, i just wanted to put the thermostat in, i have read where some say the 160 thermostat is to cold for a GTA, is that true? Or should i switch to a 170
Old Jul 27, 2002 | 03:58 PM
super83Z's Avatar
Post
Almost sounds like the air bag brain but I didn't think that 88 had that.
85-89 cars have 2 plugs into the computer
90-92 cars have 3 plugs into the computer
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28
Superramed roller 406 10.5 compression, AFR 195's and custom cam.
future mods:
N20 waiting to be installed
Wifes new car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
Old Jul 27, 2002 | 04:11 PM
Rumblin91's Avatar
Post
A 180 degree thermostat would probably suit the car better. Sometimes w/ the 160 degree thermostat the coolant doesn't stay in the radiator long enough to cool off.
