how much horsepower ????
Old Jul 18, 2002 | 01:46 AM
HeebsDiddyRSMaro91's Avatar
Question how much horsepower ????
Hey everyone ,
I was just wondering.. If I cut my cat. and put a straight pipe on, and put a flowmaster on , how many horses am i looking at gaining ? thanks ..
1991 Red Camaro RS
Old Jul 18, 2002 | 02:03 AM
stevem's Avatar
Post
probably 3 to 5 hp.you probably won't feel it but you will hear it
1987 irocz red 5.7 A4 t-tops,a/c,roof console,auto inside rear view,p/w,p/l,Ram Air,cat back(dynomax pipes,flo pro muffler,hypertech airfoil
Old Jul 18, 2002 | 02:08 AM
Post
Thanks man , one question though, should i put a straight pipe on ? is there anything else i can do to increase horsepower in this area ? thanks ..
1991 Red Camaro RS
MODS:rebuilt 350, K & N. 10'MTX.
Old Jul 18, 2002 | 10:35 AM
super83Z's Avatar
Post
I think you will gain more power than that. Prolly closer to 10 or more. If your cat is at all clogged even more. If you ahve a really built motor even more power. It all depends on a stock motr not too much.
Old Jul 18, 2002 | 12:09 PM
Ucantcme57's Avatar
Post
Lose the whole set-up and get true duals and some full length headers and an X-pipe not a H-pipe a X-pipe, X- pipes are known to give faster flow than h-pipes and dyno tests show the same gains with x-pipes as running full length open headers..
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Old Jul 18, 2002 | 12:34 PM
Blue87IrocZ's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Ucantcme57:
You can't run a true dual set up like what you are describing on a third gen. I have two friends that are pretty much only guys in the province that have true dual and they are both dual pipes that follow the route of the original pipe.
</font>
Old Jul 18, 2002 | 12:59 PM
Post
Thanks fellas for all your insight. J/W have any of you cut your cats? If so what did you put on to replace it ? 10 or more horses sounds bad as$ to me !
Old Jul 19, 2002 | 12:52 AM
RedIrocZ-28's Avatar
Post
Check the sig. I work at a parts warehouse, and I put together a "patch" that goes in place of the Cat.
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 14.423 @ 96.11 mph with a 2.08 60' (On stock programming)
Pics of the Iroc
Old Jul 19, 2002 | 11:34 PM
stonedchihuahua's Avatar
Post
I am making duel exhaust for mine? x pipe that will be able to be taken apart so I can remove it if it is stopping me from doing something.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
