383 charger to firebird???
Old Jul 14, 2002 | 11:02 AM
fire83's Avatar
From: cold nordic country where icebears are walking on the streets
Question 383 charger to firebird???
Hello!
Is it good/bad idea to install 383 engine from 68` Dodge Charger to 83` Firebird???
Are there problems with compatibility and parts? Tranny is TH-350. Any ideas??? I heard it problem getting parts for this engine and the i should still choose chevy engine.
Thanks!!!
Rasmus
//`83 Firebird SE
Old Jul 14, 2002 | 01:50 PM
angel71rs's Avatar
Post
Chrysler 383 has good bore to stroke ratioo, but that's about all it has going for it. Nothing is compatible for your vehicle. There are Chrysler to chev tranny adapters available, but mounts, headsers, and a ton of other issues will drive you to the pooer house.
Might I suggest another 383: a Chevy 350 stroked to 383 with a readily available 3.75" crank. Parts are off the shelf and in the long run you will spend much less, even if you get the Chrysler 383 for free.
Old Jul 14, 2002 | 03:29 PM
fire83's Avatar
Post
Yes its good to keep all car GM.
Old Jul 15, 2002 | 01:15 AM
stevem's Avatar
Post
the dodge 383 is a big block and you will have nothing but trouble with the install.keep the car gm
Old Jul 15, 2002 | 09:49 AM
Jim85IROC's Avatar
Post
Anything is possible with enough time and money, but you'll be using excessive amounts of both. Even if you got the motor for free, the swap would cost more than building a GM motor to put in. Not to mention the headaches. They're free.
Plus... a stock 383 is nothing special. A decent 350 could easily surpass the stock 383.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Jcastro2333
Jul 27, 2015 09:49 PM
Jlo
Jul 22, 2015 05:00 PM
silvermansteve
Mar 4, 2015 05:02 PM
