Rear wheel backspacing?
Old Jul 15, 2002 | 10:27 AM
Jim S. '95 Z28's Avatar
Question Rear wheel backspacing?
What is the rear wheel backspacing for 3rd gens? Pondering how much they will stick out on a 4th gen. TIA.
+33 cube/- $$$$ mod
"Real men drive opposite lock."
Old Jul 15, 2002 | 06:28 PM
Bad 91z's Avatar
Post
I believe its 5 1/2" on a stock 16X8 wheel, not sure though. Just know its a lot different then 4th gens
Marty
91 Z28 4L60, electric red, 355. JE 11.1 flat tops, LT-1 rods, L-98 crank. Ported trick-flows by GTP, cc 306 grind, 1.6 chromemoly rr's, LT-1 intake fabricated for L-98. Tubular k-member,a-arms,manual rack-and-pinion,coil-overs,koni spa-1's. Ford 9" w/3.89's and spool. and still more to come.
'89 Mustang GT. just got it. only weight reduction mods so far.
'99 Neon R/T daily driver
Old Jul 15, 2002 | 07:46 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
This will help: http://www.skulte.com/adapterfaq.html
Basically it'll stick out about 2" more.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
dmaastr
9
Jul 1, 2002 02:22 PM
