4th Gen rear into my 3rd Gen????
Old Aug 1, 2002 | 09:27 PM
amc91z's Avatar
Question 4th Gen rear into my 3rd Gen????
Will a rear end out of a 99 Formula work in my 91 z28??? I was thinking that it will work, but the newer rear end is wider...anybody know for sure???
Thanks,
Adam
White 91 Z-28:
Currntly a 305 TPI w/auto car.
Mods:
Comp Cam, ported plenum and runners, AFPR, air foil, 4.11 gears, and a few other goodies...soon to have an LS1 and 6-speed!!!
Old Aug 1, 2002 | 10:05 PM
super83Z's Avatar
Post
Yes it will work. And it is wider so your tires will stick out that much more. I have a 95 rearend in my car. You will get the added benefits of better brakes if you put that rear in as well.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983 Z28- 406ci
LT1 intake
AFR 195's
future mods:
N20 waiting to be installed
Wifes car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
Old Aug 1, 2002 | 11:43 PM
mr diabolical's Avatar
Post
yep it works, no modifications needed. just bolt it in, attatch brakes, fill with fluid and go.
Old Aug 2, 2002 | 12:27 AM
amc91z's Avatar
Post
How far will my wheels stick out??? Could I have the rims machined down to fit correctly or do I need new rims as well?
Thanks,
Adam
White 91 Z-28:
Mods:
Old Aug 3, 2002 | 12:27 AM
LT1Powered85Z's Avatar
Post
I believe it's 2" on each side.
I say that because with 4th Gen wheels you need 2" spacers front and rear. Once you get a 4th Gen rear, you no longer need spacers.
I'll find out in about a week...when my 4th Gen rear shows up and I'm able to put my ZR1s on.
Eric
Old Aug 3, 2002 | 10:08 AM
funina91ss's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by LT1Powered85Z:
Eric
</font>
I used 2.5" spacer on the front and 1.5" spacer on the rear if you use the stock 3rd gen rear.http://www.skulte.com/adapters.html I have pics in my sig
91 Camaro SS
305 tbi edelbrock intake &strut brace crane compucam march underdrive pulleys ads superchip k&n open air cleaner mac headers & subframe con. 3"flowmaster ascd ss hood and gm ss rims 6 speed star spec stage3 carbon fiber clutch Sphon suspension eibach sport line springs bilsten shocks and struts,mosser 12 bolt 4.11, 400+hp lt1 in the build up waiting to get the heads back. carbua targa rs seats ,pics http://www.ofoto.com/Slideshow2.jsp?...id=89850812303
stylin99
Feb 3, 2016 02:24 PM
ChrisFrez
Mar 22, 2015 07:00 PM
guruerror
Mar 4, 2015 06:25 PM
4586
Dec 31, 2014 02:21 PM
formula79
23
Jun 20, 2002 01:42 PM
