subframe connectors
Old Jul 22, 2002 | 12:46 AM
86 redbird's Avatar
Post subframe connectors
Has anyone had weld in subframe connectors put in their cars....if so how hard was it, and how exactly is the floor pan modified? I can't find anyone to do it for me, and I am sure I will need them, so I might have to try myself.
Old Jul 22, 2002 | 02:21 AM
aklim's Avatar
Post
From what I heard from Alston, it is simple. I am going down there to get them to first bolt it in and then weld it in. No cutting required.
http://www.alstonracing.com/
Old Jul 22, 2002 | 11:57 AM
RobsWS6's Avatar
Post
I have Global West SFC and you don't have to do anything with the floorpan.
I had Kenny Brown's on the 96 and they didn't need floorpan modifications either.
Rob
89 TTA #1387
11.98@118.66
Old Jul 22, 2002 | 01:09 PM
86 redbird's Avatar
Post
Were these the bolt in or weld in style. Also I'm in a 3rd gen. They say the bolt in's don't need modifications but arn't as good. I'm not for sure, but I can't find anyone to modify the floorpan to put the weld in's in anyways
Old Jul 22, 2002 | 05:42 PM
aklim's Avatar
Post
I had Global west and kept having my exhaust hitting it. From what I saw of Alston's unit, it doesn't matter because it does not run into that region where the exhaust runs along the length of the SFC. Will let you know this Fri
Old Jul 22, 2002 | 06:21 PM
AutoRoc's Avatar
Exclamation
South Side Machine sells a sweet subframe setup. It's fit on 2 of my IROCs with no clearance problems or exhaust problems. JEgs sells them for $150+ shipping i think...goodluck
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Jul 22, 2002 | 07:50 PM
IROCrdracer's Avatar
Thumbs up
another vote for SSM
90 IROC,394 ci,vortech,SR intake, Accel DFI, MSD 72lb. injectors,Accel injector cntrl,Tremec TKO, 9" Ford,NX 150 HP shot, Spohn adj ctrl arms-sway bars-race tqe arm-,Ground Control coil overs & camber plates,EDL tower brace, roll bar,Kirkey seat
my pics
Old Jul 22, 2002 | 09:45 PM
86 redbird's Avatar
Post
I thought the same. the 150 sounds better than the almost 300 the other type they have in summit was selling for
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
