Tuning fuel pressure from O2 readings?
Old Jul 17, 2002 | 10:07 PM
Chuck!'s Avatar
Post Tuning fuel pressure from O2 readings?
Ive yet to try it, but on thirdgen's tech articles it says when your readings are between .850v and .900v at WOT, then you're OK. Then someone told me that it will oscillate (sp?) between .200v and .800v fairly quickly and that .850v+ is very rich. From my WinALDL logs on my stock engine at WOT it always seems to stay right around .870v, never oscillating...?
Is the baud rate just too low on my ALDL port to see the volts varying or what?
Thanks for any help here.
Old Jul 18, 2002 | 01:33 AM
RedIrocZ-28's Avatar
Post
Chuck, as a novice like yourself at programming, which is what I presume you are gonna try to do to your EPROM, I can say that I have no clue lol Actually, I don't believe that the O2 voltage readings should vary much at WOT. There should be a table that controls your WOT spart advance and injector pulse width based on the O2 readings. I believe that it is the same as the LV8 vs. Coolant Temp and Spark advance table. Have you gotten WinBin yet to play around with?
Old Jul 18, 2002 | 08:51 AM
1989gta's Avatar
Post
What are you guys using to burn chips? Where can i get this and how much? When i had tpis try and fix my chip, mine was diping back and forth at wide open. They said this was normal.
Old Jul 18, 2002 | 03:30 PM
Chuck!'s Avatar
Post
Brad, Im not quite ready to start burning chips yet, mainly because my wallet isnt ready. Damn money. But Im going to be running higher pph injectors and I might run a vacuum afpr, but Im not sure what to tune the fuel pressure to using the O2 readings. From what I've read, thats what you need to look at.
1989gta, read traxxion's tech article about burning your own chips on thirdgen.org, then check out the DIY prom board and do some searches if you have questions. I have no idea whats going on with that stuff, but the archives over there are great.
DirtyDaveW
Dec 1, 2016 05:37 PM
Cam's maro
Jan 30, 2015 09:21 PM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
Nostang 96z
Sep 10, 2002 08:54 PM
