Alternates toTPIS Mini-Ram???
Old Jul 20, 2002 | 08:46 AM
454Corvair's Avatar
Post Alternates toTPIS Mini-Ram???
I have a 406ci SBC long block ready to go and a looking for an alternate to the TPIS Mini-Ram. At this point I prefer the same short runner design but am open to any thoughts. Thanks for any replies.
Old Jul 20, 2002 | 10:45 AM
IROC5.7TPI's Avatar
Post
Holley Stealth Ram. Very nice piece that will easily support the demands of your big inch small block
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Jul 20, 2002 | 01:20 PM
super83Z's Avatar
Post
OR a modded LT1 intake.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28
Superramed roller 406 10.5 compression, AFR 195's and custom cam.
future mods:
N20 waiting to be installed
Wifes new car:
1995 Z28
AT, leather, T-tops bone stock for now. 250 RWHP 300 RWT 14.0 @ 99 MPH on a 2.2 60'
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone (maybe)
Old Jul 20, 2002 | 01:23 PM
aklim's Avatar
Post
How about an ported ACCEL SuperRam TB, Plenum runners and Base
Old Jul 20, 2002 | 01:30 PM
86 IROC's Avatar
Thumbs up
Modded LT1 intake is what gets my vote. I have a Mini Ram, but if John had been doing LT1 intakes before I bought the Mini Ram - I'm positive I would have bought a modded LT1 intake instead.
My other choice would be a converted 4bbl carb intake. That is what I initailly wanted for my car, but I got talked out of it.
1986 IROC-Z, 8pt. cage, 383, Mini Ram, DFI, Art Carr 700R4, 12 bolt.....
Old Jul 20, 2002 | 05:26 PM
AutoRoc's Avatar
Red face
Edelbrock Victor Jr. Drilled and tapped to use 8 fuel injectors ..adapt some fuel rails and tune away!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Jul 20, 2002 | 08:56 PM
454Corvair's Avatar
Post
Thanks for the input guy's. I'll be looking into the Holley (didn't know they made one). Any pictures of how the LT1 is modified? I may be running an Electromotive TEC II so don't need to modify for a distributer, just the coolant outlet and ??? (bolt holes?)
I have a converted Hilborn with 2 1/8" butterflies but it's just a little to wild for my 87 El Camino. (You have to live with a high idle.)
Thanks again for the info.
Old Jul 20, 2002 | 09:44 PM
super83Z's Avatar
Post
www.lt1intake.com
1983Z28
future mods:
Wifes new car:
1995 Z28
future mods:
Old Jul 22, 2002 | 10:35 AM
Ucantcme57's Avatar
Post
I would go sky high, of course that's what I'm doing. Nothing flows like a 4 barrel single plane intake. get one with a fuel injector bosses and get a plenum adapter and a throttle body. doing some running around in Accel DFI adobe online catalog. Look at page 233 that is what you can make. Part number # 74139 (intake) part # 74882 (adapter) and a TB of your choice, rpm range 1,500-7,000 and you just can't go wrong
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Old Jul 22, 2002 | 09:28 PM
aklim's Avatar
Post
How about a Hogan's Sheet Metal Intake at http://www.hogansracingmanifolds.com/
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
