Lubed your... HEADLIGHT DIMMER SWITCH lately ?!?
Old Jul 22, 2002 | 12:17 AM
BigDarknFast's Avatar
Lightbulb Lubed your... HEADLIGHT DIMMER SWITCH lately ?!?
I've been having some trouble lately with the headlight dimming switch on my Camaro. The car has a lot of miles (85k), from its previous life before I got it last year. So I'm not surprised when I discover strange things needing maintenance. But the headlight dimmer had me worried... steering column and all... I had visions of costly repairs in my head. Turns out the fix was a lot simpler than I expected!
The problem cropped up about a week ago when I got the car out of storage and started driving it around. I could go to high beams, but then it would take five or six (or ten+ !) pulls on the stalk to go back to low beams... always a good way to make new friends on the road at night.
So I pulled out my trusty Camaro part drawings/numbers CD from http://www.metzcon.com/fbodymanual/order.htm (sorry had to plug this very handy CD!) and started investigating... found the dim switch and the dim switch rod, which runs along the steering column sleeve under the dash. Hate to say it, but it's really kind of crude, the thing rests right up against the column sleeve and there's enough friction -at least on mine- for the rod to even cut a little groove in the steering column sleeve over time. Anyway, I figured maybe the switch is wearing out a little and maybe it would work more positively if there were less friction between the rod and the column sleeve. So I put a drop of motor oil where the rod has made a tiny groove in the column and now it works like a charm! You have to remove five 10mm hex body trim screws to drop the knee panel from the dash to access this area - but it was well worth it (obviously should also be cognizant of airbag hazards if you have a 1990 or newer). Anyone else encounter this?
NBM 99Formula, DF Lid, FRA, K&N, SLP WS6 Takeoff Muffler | DFGreen 98 GTP, Insulated SLP K&N, !U!Res, 3.5 Pulley, transcooler
| Brilliant Red Metallic 1990 IROC-Z Camaro, K&N, Camaro SS takeoff muffler
Old Jul 22, 2002 | 12:56 PM
Damon's Avatar
Post
That's a good, cheap fix. I've had dimmer stalks that have been close to having that problem but they always seemed to keep working just well enough that the problem wouldn't become a nuisance or a must-fix. I'll keep it in mind if I ever run across this problem.
Old Jul 22, 2002 | 10:46 PM
91rs383's Avatar
Post
my car did the same thing. i have tilt wheel and would raise the wheel all the way up then i would click it and then let it back down. what a pain in the butt.
brandon
79 Z, 357, pro1 heads, victor jr.intake,
prostars, powerglide, 9" ford w/ 4.86 gear, etc...
best pass to date :10.16@132.72mph
91 rs stroked not sprayed
11.86@115 so far........
Old Jul 22, 2002 | 11:33 PM
92BLKL98's Avatar
Post
Mine did the same thing. The dimmer switch had to be replaced.
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods, removed cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
