Clutch pedals
Old Jul 15, 2002 | 09:53 AM
C-5 LOAD's Avatar
Cool Clutch pedals
O.K. guys, need info. Just checked out the local junk yard and found several cars, both 3rd and 4th gen with clutch pedals. Want to do a swap to T56 in a auto car and just wondering which ones will work the best or should say easiest. Also will a 3rd gen or 4 gen parts out of a Firebird work also and should I take the time to pull them out or just find some already out. They don't look that easy. Thanks for any info
Mike
Old Jul 15, 2002 | 10:56 AM
firechicken_3's Avatar
Post
third gen pedals aren't that hard to take out, mine took a couple hours,
remove the drivers seat, so you can lay in its place, take off all the trim under the dash, there are 6 nuts, and 1 bolt holding them on, the bolt is in front of the pedals, going straight up, the 6 nuts are on the firewall, 2 on the clutch master cylinder braces, then all 4 nuts need to come of on the brake master cylinder, this is all under the dash
if you need more detial i think there is a tech actricle over on thirdgen.org
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
