Help with parts
Old Jul 28, 2002 | 09:50 AM
spacemonkey's Avatar
Exclamation Help with parts
Hello Everyone. I am possibly looking to buy a 90' Camaro v8. I was wondering if there are any website part companies that offer staged upgrades for torque and HP? Or offer a good and wide range selection of parts?
Also what do you think the average price is for one with 140k on it. body and engine are in ok/good shape? Let me know thanks
~Geoff
*RIP*-95' Dodge Intrepid ES
92Dodge Stealth R/T tT
Coming Thanksgiving 02'
-86' 1000cc Yamaha Virago "AKA Hardley A davison"
-72' Honda 175 CB Moded.
Hooters!
[This message has been edited by spacemonkey (edited July 28, 2002).]
Old Jul 28, 2002 | 01:19 PM
91RS5speed's Avatar
Post
You should be able to get a nice one for about 4-5k. Anything you can do to a smallblock chevy you can do to the v8 that comes in the f-body u get. Just pick up a summit racing catalog.
91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Jul 28, 2002 | 03:19 PM
RedIrocZ-28's Avatar
Post
There really aren't any staged upgrades as you talk about. Thats more of a ricer-esque term.
Like said before, grab a Summit catalogue at www.summitracing.com and have fun.
I would not expect to pay much more than $4000 for that car. I got mine 2 years ago with ~115k on it for $5000.
Old Jul 29, 2002 | 12:57 PM
Ucantcme57's Avatar
Post
It will cost you !!! And yes there are places who do it and I wouldn't say that it is Ricer-esque I would say that it is a good platform for someone to start with. www.tpis.com they have cam and chip, cam, chip, head , they have all kinds of stages. But your money would be better spent with coming up with an realistic idea of what you want and where you want to go and first off... How much are or do you have to spend..?
Alot needs to be done to these cars..
First off is it a TPI?
How many Miles?
How much do or can you spend?
I would first do the Exhaust. Get some headers. 1 5/8 primaries that collect to 2.5" or 3" collectors. Do you have to run a catylitic convertor in your state? I don't in michigan. have true duals ran with X pipe somewhere in the middle ( the best place to find where to put it is paint the exhaust and drive it, where the paint is totally gone, is where the hottest part of the exhaust is and there needs to be scaveging there) put your X pipe. have the mufflers go straight from front to back ( kinda like the corvettes. ( not the new ones) If you bought the headers on here somewhere, and had a local shop do the rest your looking at like 300.00 but you will never need a better exhaust. next build some sort of ram air ducts. www.thirdgen.org has some technical articles that will show you how. Also go here..
http://www.gmtips.com/3rd-degree/dox/tips/tips.htm
Go there that guy has done lots of free things that will boost performance.
Port your plenum, he talks about it in there, Siamese your runners, and port your base. Gasket match everything.
Then get some good cheap heads.
Dart heads are good!
World Products make dart heads, there just different named for more money.
go to www.theengineshop.com
and get some aluminum motown heads, great price..
The get a good Cam nothing with a redline over 6k Your TPI won't support that anyway.
www.crower.com - Great Cams, and the technical dept will help you choose a cam that will best work for your car, just tell them what you have. Upgrade to a 52 or 58 TB and then maybe some 22 or 26lbs injectors all that is better than getting stages of phases, cause alot has to do with the chip and unless you want to learn how to burn your own chip, you will be buying lots of chips with every upgrade, so only buy one chip at the end or something.. Just some thoughts, Don't order a off the shelf chip, get one custom made for what you have and what you have done!! Off the shelf chips suck!!!
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Old Jul 29, 2002 | 01:28 PM
aklim's Avatar
Post
www.lingenfelter.com
www.hitechmotorsport.com
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
