instrument panel light problem
Old Jul 28, 2002 | 11:33 PM
86 redbird's Avatar
Post instrument panel light problem
Yesterday durring the evening when i turned my lights on i noticed what i though to be a bulb out in my instrument cluster....the last pod(86 TA) with the temp and oil pressure. So to day i tore out 2 million screws and i replaced the bulbs...but they still don't work....i think i found the problem on the back of the cluster in the circuit paper stuff. There are a couple places that arn't connected and look burnt. CAN I FIX THE CIRCUIT OR DO I NEED A NEW ONE?
Old Jul 28, 2002 | 11:42 PM
stanghunter211's Avatar
Post
damn bro, your bird is turning out to be an electrical nightmare isn't it?!?!? I know on my circuit panel, there were a number of empty slots. Depending on what you had, not all slots were filled. Some had different purposes, ie warning lights that might not have been needed in your ride. Like mine has a provison for "down shift" or something and I have an automatic, so there is no light there. I hope that helps. Try a fuse maybe? Or a loose connection somewhere!
Will
'86 Z-28 305 c.i. LG4
Rochester QuadraJet 4bbl
Flowmaster 80 series Chrome Tips
Dual Snorkel Air Cleaner
K&N Filter
Michellin P215/65/R15 X-Radial Plus
Lots of Mods on the way
Pioneer 4"x6" dash
Pioneer 6"x9" rear
Alpine 8" Type S in bandpass box
Alpine Amp 300x1 bridged
Sony 4000X- x-Plode Deck 50w x4
Soon to be sporting Hooker SuperComp Shorties, CompCam Xtreme 256H, Edelbrock Performer EGR, World Sr Torquer 305's, DynoMax Super Converter, and American Thunder 3" Cat-Back !!!
http://camaroz28.cardomain.com/id/stanghunter211
Old Jul 28, 2002 | 11:49 PM
86 redbird's Avatar
Angry
Yeah i see a bunch of those empty slots too....I found the shift light( i also have an auto)
But the problem I think is in the circuit it self( wish i could draw a pic to show everyone) it is like the circuit burnt in two in a few places.....How much would a new cluster cost me? used of course. And would a different cluster work in my car.
I've noticed clusters with different tach's Mine only goes to 6 I would like one that goes to 8 if i have to buy a new one....
Old Jul 29, 2002 | 12:15 AM
91RS5speed's Avatar
Post
I now have 2 bulbs out and one is the speedo. How long did it take you to swap the blubs and what all do you need to take apart to do it?
91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Jul 29, 2002 | 09:46 AM
Rumblin91's Avatar
Post
It's really simple..shouldn't take long at all. Take off the bottom panel (under steering wheel). There are 3 torx screws all the way on the bottom and 2 hidden by those circle things in the middle (just pop them out w/ a screw driver). After you take that panel off, you can see the 2 screws to get the top bezel off (have to disconnect the cigarrete lighter and take out the light ****). Remove the screws for the cluster, unhook the two connectoins from the back, and it comes right out.
Old Jul 29, 2002 | 03:49 PM
86 redbird's Avatar
Post
Mine is a TA not a camaro, so it is different, but mine was a pain in the ***. I have a whole bucket of screws. I first had to take off the dash, and then i had to remove the small plastic that covers up the computer on the passenger side, then i removed the small pieces that hold the fog light swithces, rear defrog, hatch release and so on. then with six screws all of the guages came right out and the bulbs were in the back.......easy.....ha
[This message has been edited by 86 redbird (edited July 29, 2002).]
Old Jul 29, 2002 | 10:01 PM
86 redbird's Avatar
Post
Good news for me, I fixed it. I called the GM garage and they told me gm didn't make them anymore, so i decided to try to fix mine.....a little soder and it is fixed.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
