from tpi to carb
Old Jul 29, 2002 | 04:51 PM
PonyEtrZ28's Avatar
Post from tpi to carb
after TONS and TONS of issues with this tpi set up, ive had enough. so where can i find info on doing this tpi to carb swap?
if anyone is interested. im selling everything i have that uses the tpi set up.
slp ported siamesed runners, eldelbrock ported base, ported plenum to match the runners and manifold,58mm edelbrock tb,255lph
walbro fuel pump,26lb accel injectors,
mass air, ill sell the harness as well!.
1987 IROC-Z
355ci, Dart 2.02x1.60, compete forged bottom end, SLP siamesed runners, fully ported Edelbrock manifold and plenum, 58mm TB, Accel 26lb Injectors, Edelbrock headers & y-pipe, Flowmaster 3" cat-back, Rebuilt 700r4, B&M Megashifter, Holley 255lph fuel pump, triple guage pod, !A/C & Heat, !Smog pump, bypassed TB, MJS Ram air, custom PROM, Lakewood control lower control arms, Lakewood adjustable pan hard, Sub-Frames, Hotchkis Strut tower brace, Adjustable Torque Arm, 150hp NOS
IROC Pix
Old Jul 29, 2002 | 06:18 PM
AutoRoc's Avatar
Red face
I did this on my 305 TPI
Holley 600 CFM Carb
Mallory 3 port fuel pressur regulator
Edelbrock Performer Intake
TBI water neck
TBI upper radiator hose
New 160 degree thermostat
Proform Mechanical distributor
misc. 1/2" pipe plugs(for intake and regulator) You could probaby use a 2 port regulator now that i think about it.
Rubber fuel lines need to be moified if you can't find adapter fittings. Nobody makes 5/16" or metric(whatevr the fuel feed and return lines are..) to 1/2" stuff around here. I pressed a new fitting onto my old hose. A 3/8" fitting onto the rubber hoses
FP set at 6.5 PSI, the stock fuel pump works(had a probem lately however it wouldn't kick on so we hot wires it to the ignition..also presented problemn of car not shutting off afterwards.m till the hot wire was cut..grr..hmm ), all the guages work. FANS WILL NOT WORK UNLESS...you do what I did. Using the stock relays, wire the fan(s) up to a manual switch. It's so much better. I can get my temps down from 240 to 160 in under 2 minutes idling. EASILY.
The new ditributor only has to be spliced into the stock wirin harness..Find the right wires, make a connector somehow and viola, it works like a charm. I didn't use my Vacuum adance but it advances perfectly anyways. Hooking up the vacuum advance only added like 2 or 3 degrees so we just played with the base timing. I got it at 4 degrees because i'm gonna spray a 100 shot sooner or later and that worked ok when I was using the TPI stuff... Goodluck man!! The enhanced top end charge is phenominal!! You DO lose a little off idle power but man does my car rev to 5500 nicely
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Jul 29, 2002 | 08:43 PM
mjcent922's Avatar
Post
ahahahahahah why on earth do you want to go with a carb?That's like taking a big step back intime.The tpi setup is great and efficent.Just look at gmhightech performance 88formula projectcar.No carb,smog friendly(will pass state inspection) a/c, n/a and a lot of power low 12's maybe high 11's don't know yet but impressive!Keep the tpi don't give up.BTW what r your problems that your having?????????
Old Jul 29, 2002 | 09:51 PM
AutoRoc's Avatar
Post
Does GMHTP still have the long runner setup on that 396 or did they finally do a SuperRam intake?
If they did a superram, they are smart and that's why they have ran a little btter times. I really don't understand why they built that hardcore 396 and matched i with all of those accel long intake runner pieces. They were honestly giving up 50+ HP on the top end.
Denny Villemure
www.denny.cz28.com
Old Jul 30, 2002 | 06:33 AM
Rob L98's Avatar
Post
what are you going to do with your tpi set up
Old Jul 30, 2002 | 11:25 AM
Zepher's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Rob L98:
what are you going to do with your tpi set up</font>
I am not sure, but I could have sworn that he said he is going to sell it.
Personally, I'd stick with the TPI.
I went from carb to TPI last year cuz I was so tired of messing with the carb.
Now I've got an LT4.
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, MSD 6A & Blaster 3 Coil,
LT1 3.42 Posi/Disc Rear, Lakewood LCA's & Adjustable Panhard Bar,
Eibach Lowering Springs, 17x9 WS6 Wheels, T-Tops,
Custom 4" CAI w/ K&N Filter, 160*stat.
Autometer TriplePod with Phantom A/F & Boost Gauges.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
Old Jul 30, 2002 | 11:29 AM
Rob L98's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Zepher:
if he wants to sell it let me know i may buy it from him
</font>
Old Jul 30, 2002 | 03:59 PM
ViperXx's Avatar
Post
I would like to buy you're setup too if you decide to swap out.. I currently have a TBI, its alright but performance of the TPI would probably be 95% better
1989 Camaro RS Convertable
350 ci Throttle Body Injection
(no mods yet, mostly stock except the 305 was removed and replaced with a 350)
Suggestions very much welcome!
1996 Pontiac Firebird 3.8L v6 (Stock), Black
1986 Chevrolet Camaro v6 2.8L (Stock)
Old Jul 30, 2002 | 04:44 PM
PonyEtrZ28's Avatar
Post
mjcent922.......
my problem is.... car runs perfect when idling. but when i click on my fans or headlights, anything that draws current, my car stumbles and dies!. i had the battery and alternator checked. i guess they both are ok. fuses are good, havent blown any.
and now my tranny took a dump again!.
Old Jul 30, 2002 | 07:35 PM
mjcent922's Avatar
Post
Well I'm stumped.You might want to try a good shop if you can find one by you.I know of 2 but 1 is in new jersey and the other PA.Cartek is in NJ. and Stropespeed is in Pa.Goog luck and don't give up on the tpi.
Old Jul 31, 2002 | 05:57 PM
Duke's Avatar
Post
I think the cost to make TPI fast doesn't outweigh what you save in gas money in comparison to a properly tuned carb (but most people can't tune a carb properly, and tuning a TPI costs alot and usually it takes a few tries to get it tuned right, each try costs more).
That's my opinion, not my suggestion.
Old Jul 31, 2002 | 11:36 PM
PonyEtrZ28's Avatar
Post
well no you see the thing is. i already did spend the money, its the fact that everything else in my car is messed up.
i mean not only do i have problems with my headlights, and fans, that make my car go crazy. i have more electrical problems.
now my power locks dont work, my horn doesnt work, and i can control my fuel pump by my power windows!!!!!!!!. such as i can keep it priming by clicking it. so, tpi isnt my problem. its the whole wiring in my car!.
1987 IROC-Z
IROC Pix
G-BODYT56
Jan 14, 2022 11:14 PM
Kawi
Sep 28, 2015 09:01 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
