converting from 305 TBI to 350 TPI ???
Old Aug 1, 2002 | 02:03 PM
john-e-boy's Avatar
Post converting from 305 TBI to 350 TPI ???
I have a 92 RS 305 TBI in my car now and I want to take it out and put in a 350 TPI from this 89 camaro. What all will I have to take out of this 89 to make the TPI work in my 92?
computer?, Wiring harness and how much of it?, etc.
I also want to make the 89 run with the 305 in it.
Any help is appreciated.
John
Old Aug 1, 2002 | 02:45 PM
NJ SPEEDER's Avatar
Post
you need to get the engien wiring harness, ecm, and sensors from both to switch them. also, the upper radiator hose is different between the two.
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Aug 1, 2002 | 06:34 PM
Chuck!'s Avatar
Post
And a higher pressure fuel pump.
Old Aug 2, 2002 | 03:12 AM
john-e-boy's Avatar
Post
What sensors are you talking about?
Will I need the whole computer or just the Prom?
If I take the whole computer will it plug right in?
What is the difference in fuel pumps, Will I definately need a higher one? (I just changed it)
John
Old Aug 3, 2002 | 01:48 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
TBI uses a 15 PSI fuel pump, and TPI uses 50+ PSI, so yes they're different.
There is a tech article on www.thirdgen.org that walks you thru the changeover. Its not complete and there's a few errors, but it'll get you thru. If you have no mechanical knowledge or experience, you will have a very tough time. You will definitely need the TPI computer and wiring harness, altho its possible to re-pin your existing TBI harness like my dad did. When he converted his stock 305 TBI to TPI, it gained 17 RWHP and 70 RWTQ.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
daves91z28
May 12, 2016 06:19 AM
linz
Oct 22, 2015 07:59 AM
Amshnock
14
Jan 18, 2015 11:47 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
4586
Dec 6, 2014 05:20 PM
