Fuel injector equation.....................?
Old Jul 27, 2002 | 03:46 PM
ZDADDY92's Avatar
Post Fuel injector equation.....................?
I seen an equation a while ago in one of my CHP's that gave you a fairly good idea on what size injector you needed for your application. Anyone out there remember it???
Thanks in advance
92 Z-28
305TPI-5speed
3.42gears
B&M RIPPER
K&N AIR FILTERS
Hypertech Fan Switch
160 THERMO.
14.7@96MPH(stock run)
Old Jul 28, 2002 | 06:22 AM
aklim's Avatar
Post
http://www.rceng.com/technical.htm#WORKSHEET
Old Jul 29, 2002 | 12:34 PM
Ucantcme57's Avatar
Post
Max Hp X .45 (N/A Tune) or .55 (blown or Turbo) / # of injectors.
Sample;
350hp X .45 / 8 injectors = 19.69 lbs.
*** Always round up so that you don't run a lean condition. ***
Mine;
505 X .055 / 8 = 34.71
Round up to 36's
That's where I got my number..
Hope you understand, if you need more help please email me.. I also have desktop dyno, good for coming up with a hp figure.. (not exact but better than guessing)
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Old Jul 29, 2002 | 01:26 PM
aklim's Avatar
Post
Not sure I like that equation. I would calculate it so it would support the level of power at 80% duty cycle so it would not go static which is a contidion where the injectors are held open.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
