Need some Help
Old Jul 14, 2002 | 04:19 PM
91 Redd Sledd's Avatar
Post Need some Help
Ok heres some backround on my car.It's a 91 Z-28 convertible.305 TPI stock motor with 94,000 miles.It has mild bolt ons.Gutted air box,K@N's,Air Foil,2 1/2 duals all the way back to the back seat into a flowmaster merge collector 3" over the axle single in single out 80 series,3:73's, Factory converter. I dynoed at APE on 5/4/02 she put down 209.4 HP @4600rpm. and 266.6 ft/lbs @ 3800rpm. I was pretty happy with the results for a 305.But you know how it goes....It's never good enough. I recentley dyno'd again at superfest on 7/5/02 later on in the evening @ 8:40 pm when it was cooler out.I added a Crane HI-6 ignition w/a LX-92 Coil,Ed Wright stage 2 chip,Holley Adj Reg factory pressure was @46 we bumped it to @48 cause the guy at ape told me it was running a little lean.I also added some headers that are I think 1 3/4" and are supposed to be SLP's. They look really crazy. any way my power dropped to 206.8hp@4500r's and torque dropped to 255.5 @ 3700r's. The guy from werx motorsports told me that the headers were too big for the motor. Does any body have any ideas or suggestions for me??? I would hate to spend $600 to lose 5 HP and 10 FT/LBS. The best time I've gotten with the car was 14.4@99.02 w/a 2.0 60ft.Not to bad for a heavy car with a little mouse.And that was after all the mods. Thank you in advance for the help.
James
91 Z-28 305 H.O. 210 RWHP
crane hi-6,holley reg,air foil,3:73 richmonds,Ed Wright stage 2 chip,msd wires,SLP headers,best e.t 14.4@99.02mph
95 S-10 Blazer 4.3l A4 W/230,000 original miles.Never been touched but getting tired.Still likes to do burnouts!!!!
Old Jul 15, 2002 | 02:14 PM
Post
TTT
Old Jul 15, 2002 | 02:18 PM
IROC5.7TPI's Avatar
Post
Its the gear James. Way too much for a TPI and even more so a 305. The most you want with a TPI engine is a 3.42.
I know a guy from the boards that will swap it out for you cheap. Let me know when you are coming back to town if you want it done.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
