Question on removing thermostat on 305 TPI
Old Jul 25, 2002 | 06:14 PM
Wallace1990's Avatar
Question Question on removing thermostat on 305 TPI
Hi, on my GTAs 305 TPI do i need to remove the throttle body in order to get the thermostat out or will i be able to pull it out with the throttle body on? Thanks
Old Jul 25, 2002 | 06:31 PM
Zepher's Avatar
Post
You should be able to remove it with the throttlebody still on.
I was able to change thermostat housings with the throttlebody still on, the SLP Dual Cold Air Intake comes with a new radiator hose and a housing that exits towards the driver instead of straigt ahead.
Here is a pic of my old engine bay showing the new housing,
http://www.donpagevideo.com/pics/transam/engine_drv.jpg
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, MSD 6A & Blaster 3 Coil,
LT1 3.42 Posi/Disc Rear, Lakewood LCA's & Adjustable Panhard Bar,
Eibach Lowering Springs, 17x9 WS6 Wheels, T-Tops,
Custom 4" CAI w/ K&N Filter, 160*stat.
Autometer TriplePod with Phantom A/F & Boost Gauges.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
[This message has been edited by Zepher (edited July 25, 2002).]
Old Jul 25, 2002 | 06:56 PM
Z28ROC's Avatar
Post
It can be done, but I didn't want to fight it. So I just pulled the T-body. Much easier that way. Plus it gave me an excuse to clean it out real good.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
markaubuchon
Jan 14, 2015 01:48 AM
cmdeshon
Dec 27, 2014 10:06 AM
hotrod 5210
Dec 22, 2014 07:28 AM
lbrowne
Nov 13, 2011 04:25 PM
Carguy00
Aug 6, 2002 10:25 PM
