Put edelbrock carb on 84 trans am , question about timing advance.
Old Sep 5, 2004 | 10:20 PM
BigJustinZ28's Avatar
hey guys , I put a 600 edelbrock carb on my fiance's trans am (formerly known as "my beater" to replace a dying 20 year old quadrajet. It runs great but it seems like the car has actually slowed down , then I got to thinking , will the car still advance the timing without the tps getting a reading ???? If not what can I do ??? is there a TPS retrofit or do I need to go old school with a Vacuum advance HEI from late 70s fbody ??? Let me know guys I have no Idea what to do !!!
Old Sep 6, 2004 | 09:50 AM
Marc 85Z28's Avatar
Re: Put edelbrock carb on 84 trans am , question about timing advance.
There you go! Without a functioning CC carb, the ECM will not command advance from the distributor. You will need a non-electronically controlled HEI.
Does it have an auto trans? Again, without the proper inputs, the torque converter lockup will no longer function. You will need a wiring kit to make it functional again.
All this info could have been obtained through a search, as this is one of the most common topics here... Why a moderator/administrator can't take the time to make a sticky out of one of these threads is beyond me.
Old Sep 6, 2004 | 12:22 PM
Thanks , I didnt know it was so common a question . I guess it will be alright for now , the torque converter seems to be locking up just fine and even tho the car seems a lil slower , low end seems better and the gas mileage seems better altho I noticed now it smokes a little white smoke :/ instead of the rich black smoke it did with the dead quadrajet. Looks like theres more wrong with it than I thought. It does generally RUN good tho , its super reliable.
Lederman1976
Nov 30, 2014 05:21 AM
siguy
Nov 27, 2014 10:07 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
carcrazyQT
Sep 17, 2002 07:54 AM
carcrazyQT
Sep 3, 2002 02:51 PM
