3.27's or 3.70's for a TPI 350? (9 bolt)
Old Sep 10, 2004 | 09:58 AM
Dyosis's Avatar
I have a set of 3.70's but I just found some 3.27's for real cheap. I know 3.70's would be the best bang for the $ if I had a Stealthram to complement the gears, but right now I don't. I'll eventually get a Stealthram, but currently I am just going to run my TPI setup.
Should I just swap the 3.70's in and live with it until I can get a Stealthram, or should I get the 3.27's and have them put in and just hang on the the 3.70's until I can get my motor all setup first?
Please help me out here, I don't know what to do and I don't want to make the wrong decision.
Old Sep 10, 2004 | 10:16 AM
91LT16SpdFormy's Avatar
Re: 3.27's or 3.70's for a TPI 350? (9 bolt)
If your putting them in the car in your sig,I would do the 3.70s.Youll love once you put them in.
Old Sep 10, 2004 | 04:49 PM
unvc92camarors's Avatar
i would actually use the 3.27s with the tpi and the 3.70s with the stealthram
reason being, the 3.70s are going to like a higher revving car it seems like rather than the 3.27s
now if your tpi made power above 4500rpms it might be a different story
Old Sep 10, 2004 | 10:11 PM
mrr23's Avatar
do things for the end result. that way you don't spend money twice. 3.70s
Old Sep 11, 2004 | 02:47 PM
MY91Y84's Avatar
if he wants his car to be slower now then go with 3.70's....itll be faster to 50 or so maybe even 60, but dude it will REALLY fall on its face.....
prime example....my buddy has a 91 z with G92...that gave the car 3.23 gears...ran 14.1-2's all day factory beside a K&N....he swapped the gears for a 3.73 and ran 14.3-4's...the 60 foot,330 and 1/8 were all a little quicker, but he lost over a half second after that.....
Old Sep 12, 2004 | 12:10 AM
AutoRoc's Avatar
Do the 3.70's and it WILL make you get the StealthRam swap completed faster. The car will be spinning hard out of the hole and falling right on it's face once third gear hits.
A Stealth ram will really help on the top end. So would a matching camshaft. Cylinder heads always help but that's an entirely new episode, isn't it? Goodluck!
Old Sep 13, 2004 | 01:50 AM
Tru2Chevy's Avatar
I vote 3.70s. And the car will only be spinning out of the hole if he doesn't setup the suspension right.
- Justin
Old Sep 17, 2004 | 01:39 PM
95redvert's Avatar
Go with the 3:70's. If you know you are going to be doing a HSr swap then why do a gear swap twice?
Old Sep 17, 2004 | 04:39 PM
Scrote's Avatar
The 3.70's will be just fine with your aplication, I ran a 10 bolt 3.73 gear in an '85 WS6 with a TPI motor and it went just fine. Yeah you will reach that dreaded 4750rpm faster with the 3.73 gear, but if you are looking for high rpm operation the tpi is the wrong setup anyway.
Thats my .02
Erik
Old Sep 20, 2004 | 07:41 AM
Botch's Avatar
The 3.70 will be quicker, even with the TPI, but only if you can hook it up. My car dropped .2 seconds with the swap from 3.23s to 3.73s in the 60 ft. I dead hooked with both gears and went from a 2.0 60' to a 1.815 60' with BFG drag radials on a good track. It is easier to spin off the line though so traction is key here. With the stock convertor the 1 to 2 shift really hurts the track time with the 3.23s and it is less noticable with the 3.73s. Go with the 3.70s and you will be set for future mods too.
Charlie
daves91z28
May 12, 2016 06:19 AM
dfarr67
Apr 10, 2015 07:44 PM
maybe2fast
Mar 16, 2015 09:45 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
4586
Dec 6, 2014 05:20 PM
