mini tub???
Re: mini tub???
Not sure on the minitub, but S&W sells a complete rear sub frame kit to mount big ole tires under a 3rd gen.
http://www.swracecars.com/rearframes.asp#82
Re: mini tub???
No such thing as a minitub on a third gen. The frame rails, if you can call them that on a third gen, are already at the inner fenders. The best thing you can do is to cut off the bump stops, cut out the section over the spring and replate with a thinner piece of sheet metal and cut out the front inside corner if your wheels are too tall to fit.
Re: mini tub???
i want to run a at least a 295 but the wider the better(315,335)
i am doing this for cornering not for drag racing
Re: mini tub???
This is a perfect question.. I want to know as well.. I know I will probably have to roll the fender lip, bang in the inner fender alittle.. but what rim dimensions should use... I have a 4th gen rear so that throws things off too???? I want a 17 inch rear rim. like a 315/17/35.. But what should I get the backspacing like?
Jul 17, 2015 02:47 PM
cavemanmoron
3rd Gen / L98 Engine Tech
Mar 16, 2003 10:43 AM
69SUPERCAMARO
Classic Engine Tech
Feb 11, 2003 09:50 PM
