Guage cluster questions. Maybe you have the answer.
Old Sep 2, 2004 | 06:19 PM
Pneumatic_Tire's Avatar
Are the gauge clusters on these 3rd gen camaros good for taking dumps? Sometimes my water temp gauge goes up to like 240 ish, and if i flick it hard enough it goes back down to just under 220. Today, my oil pressure gauge started bouncing around a little when i was stopped idling in drive to get my tacos at taco bell. I put it in nuetral, and it quit jumping. When i am driving, it seems to work fine. If i nail it, it raises like it should, and when i slow down, it goes down smoothly. Anyone ever have these issues? Thanks.
Old Sep 2, 2004 | 09:38 PM
Ben91RS's Avatar
Re: Guage cluster questions. Maybe you have the answer.
Yep, I think that at least half of the 3rd gens out there have at least one serious problem with their stock gauges. I have 2 myself. The stock tach is way off (always reads 1000-2000 RPM high) and my speedometer and odometer won't kick in until about 3 to 4 minutes of driving .
I think the biggest problem is that it seems no one really knows how to fix the problem (unless its wiring or a sensor of course). The only thing I can think to check for is loose or corroded grounds, bad wires, and the sending units for the gauges themselves.
Wish I could help more.
Old Sep 2, 2004 | 09:43 PM
I figured I would'nt be the only one. Im half tempted to just trash this cluster and go after some custom ones I saw online somewhere one time. I may rip it apart and check out the grounds and what not. By the way, my temp sensor is brand new, so it shouldnt be my problem.
Old Sep 3, 2004 | 10:47 AM
Ben91RS's Avatar
I agree, I also think that the only real way to get accurate readings from gauges is to go aftermarket, just like you said. I've seen some people with some custom Autometer gauge set-ups in 3rd gens and they look good, but it does cost some $$$.
Old Sep 3, 2004 | 02:16 PM
Tru2Chevy's Avatar
Yea, stock gauges suck....wish I had the money for the Covan's Classic setup
This is what I want:
http://www.covansclassic.com/parts/d...9144.81.170.96
- Justin
Old Sep 6, 2004 | 12:12 AM
buzz12586's Avatar
- Justin
That looks awesome but it is kinda pricey. The only thing I would switch is the tach and speedo locations cuz the stock ones are on the other side.
Old Sep 7, 2004 | 08:25 PM
85_305's Avatar
Ya know.. it's funny you mention cluster-"***cs", lol.. my speedo pulsates up and down when driving (like up a few miles an hour, down a few miles an hour). Why do the gauges in 3-gen's stink so bad?
Old Sep 8, 2004 | 01:11 AM
slimdawson's Avatar
I am not sure but I think 85 speedos are cable operated. The variations could mean a sticking cable. A good greasing may take care of that. Replacing it definately should.
Old Sep 8, 2004 | 02:41 AM
CtRw's Avatar
I switched to autometer after my engine swap. I did a 5" speedo and tach plus 3 2 1/6" guages. A friend and I just outlined the stock bezel then measured out our own holes and cut it out of plexiglass. Painted the back of it black and it looks awesome, I'll try to find a host for a pic. Guages ran $468 plus the $9 for plexiglass.
Old Sep 8, 2004 | 02:16 PM
85_305's Avatar
Where would you grease/lube in a cable operated speedo?
Old Sep 8, 2004 | 02:27 PM
buzz12586's Avatar
Yea I have the same question...
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
ZXXVIII
Sep 1, 2015 04:14 PM
4586
Aug 13, 2015 10:11 PM
alphaauto
Jul 26, 2015 04:40 PM
