How many of u leak oil
Old Sep 8, 2004 | 08:23 PM
lordmetalz28's Avatar
so my engine leaks oil from the from main seal, back corners of the oil pan, also leaks rear fluid from the rear seal, even after it was rebuilt, also leaks coolant but can never tell where its going, not a head gasket oils fine, tiny bit of brown sludge in the overflow, tiny tiny bit, but its been there since i bought the car. just wondering who else leaks fluid everywhere like me
Old Sep 8, 2004 | 08:39 PM
PyRo9862's Avatar
Re: How many of u leak oil
I have a small oil leak, its up front and I havn't really looked to see where it's comming from. Probably from around the timing chain.
The rear end is covered in grease around the driveshaft i'm not sure if it is an actual leak or just thirteen years of accumulated crap.
I'm also leaking coolent into the oil
Old Sep 8, 2004 | 08:52 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Just about every gen I sbc Ive ever seen had minuscule leaks from the timing chain cover or something.
Old Sep 8, 2004 | 10:01 PM
Dragula85Z28's Avatar
I got nice leak coming from the rear of the engine i have not pin pointed it yet but im 90% positive it's the rear main seal.
Old Sep 8, 2004 | 10:25 PM
Stephen 87 IROC's Avatar
My major oil leaks get a minor tear down depending where they are. The minor oil leaks get lots of silicone. I just tore my engine down to fix a spun bearing. There's silicone on the front pan seal, around the dipstick hole (BBC is in the pan not the block). There's silicone on the front and rear intake gasket (don't use the rubber seals in the kits). There's also a bunch of silicone at the 4 corners of the oil pan plus a few other minor spots on the engine that were giving me some problems.
When I took the engine out there were no major oil leaks. Just the typical damp spots. One thing I did to help seal the rocker covers was to buy thick cork gaskets. They seal the best for the price.
If a rear main leaks, the engine comes out to fix it. I can't pull the pan off with the engine in the car. Good thing is that I can have the engine out and sitting on a stand in about 90 minutes.
Old Sep 9, 2004 | 06:16 AM
Dave89IROC's Avatar
all mine are dry
the 4x4 is leaking trans fluid and p/s fluid though
Old Sep 9, 2004 | 08:47 AM
Donohue96M6Z28's Avatar
i got a rearmain seal leak, valve cover gaskets, intake manifold, and who knows where else! lol they'll all be fixed this sunday hopefully
Old Sep 9, 2004 | 04:58 PM
Marc 85Z28's Avatar
My 125,000 mile 305 used to leak from every seal! Since the 355 was dropped in (over 5 years and 50k ago) I haven't had a single leak since. Not even a little "seepage".
Old Sep 9, 2004 | 08:51 PM
i use 10w 30 max life with lucas stabalizer, looks like ill bump it up tommrow with 10w 40 and stabalizer, besides colder weather is coming.
Old Sep 9, 2004 | 09:04 PM
buzz12586's Avatar
My leaks a little bit and it has gathered up over the years cuz its over a lot of the bottom of the car. I burn a little on start up as well.
Old Sep 10, 2004 | 08:25 AM
hairbear's Avatar
Yeah front seal/timing chain cover here also. Valve covers because the bleep valve cover bolt broke of in the world product head and can't get it drilled out
Old Sep 10, 2004 | 04:17 PM
IROC-T's Avatar
Not a drop,just over 100k. Valve cover gaskets leaked about four years ago replaced and good ever since.
Old Sep 11, 2004 | 12:06 PM
LandryP's Avatar
every gm I've owned and currently own has leaked something. My Camaro doesn't leak oil since I replaced the smashed oil pan, but pisses power steering fluid when its parked (despite many attemps to fix it) my Firebird leaks oil pretty good from the rear seal same with my Trans Am. My brothers cutlass leaks oil from somewhere, my sisters grand am leaks oil and brake fluid from the clutch. My driveway and the street in front of my house are a total disaster
Old Sep 11, 2004 | 02:38 PM
IROC-T's Avatar
LOL! They'er not leaking ,they are marking their territory.
Old Sep 12, 2004 | 12:03 AM
85_305's Avatar
197k on my Z, and NOT ONE LEAK! GO CHEVY POWER!
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
surreybrad
Apr 22, 2015 06:40 AM
artic94
Jan 17, 2015 11:19 AM
Jessie4tin
Jan 7, 2015 08:53 AM
