When rebuilding ?'s
Old Oct 11, 2004 | 12:22 PM
Buck89RS's Avatar
When rebuilding ?'s
Do i need to fill the block up with coolant before i put the t-stat on so that it will have some in the block before i put the engine back in the car? Thanks
-Buck
Old Oct 11, 2004 | 01:38 PM
zrs's Avatar
zrs
Re: When rebuilding ?'s
Put engine in the car then fill up with coolant.
Old Oct 11, 2004 | 01:46 PM
Buck89RS's Avatar
Thanks. So i imagine the coolant flows from the bottom rad to hose, through the engine, and out the top, correct?
Old Oct 11, 2004 | 01:50 PM
aklim's Avatar
For the most part, yes. Unless you have something like an LT1 which is reverse cooled. Also some of it goes to the heater. Just fill up the radiator and crank the engine over a bit with the ignition coil disconnected so it moves it a little and fill it again. Then run the car and keep filling till it stops needing coolant
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
