Which cam?
Old Oct 2, 2004 | 09:22 PM
85_305's Avatar
Which cam?
Ok.. here are my mods, and future mods:
Performer 600 carb, performer intake, hedmann headers, hi-flow cat, aftermarket distributor (accel I think..).
I am looking for a cam that makes some damn fine power, keeps an almost stock sounding idle, makes power (i am looking for maximum torque over hp) from idle to maybe 5500 rpm, maybe a BIT lower, and something that does not suck gas.
All help appreciated,
Matt
Old Oct 2, 2004 | 10:27 PM
teke184's Avatar
Re: Which cam?
sounds like a contradiction in terms
good power, stock idle, doesn't suck gas......good luck
maybe look into some of the truck cams...since they are optimized for torque..needed for towing.
Old Oct 2, 2004 | 10:47 PM
85_305's Avatar
Re: Which cam?
ok, well i dont care about anything except for gas sucking I guess. as long as it makes great power, and doesn't suck gas, I can live with the others.
Old Oct 3, 2004 | 12:36 AM
V8Rumble's Avatar
Re: Which cam?
OK, it's not the most thorough resource, but this page will give you a rough idea, maybe enough to get you started...
Hope it helps.
Old Oct 3, 2004 | 01:22 AM
AutoNewb's Avatar
Re: Which cam?
Yeah, if you dont wanna suck gas, you probably don't wanna drive a modded camaro...
Sort of a contradiction of terms there as well...an american v8 that doesnt chug gasoline...
My buddy had that problem with his 5.0 thunderbird supercharged. He ended up payin like, 500 bucks for a cavalier clunker to take to work and stuff...its a decent idea...if you dont live in new jersey...or near new jersey, heh.
Old Oct 3, 2004 | 02:54 AM
V8Rumble's Avatar
Re: Which cam?
Heh - yeah, when you think about cars, it seems that you pretty much have to look at it this way:
  • Economy / MPG
  • Reliability
  • Power
You can pick any two you like!
Old Oct 3, 2004 | 11:48 AM
Rice Killer87's Avatar
Re: Which cam?
www.compcams.com
check that out and look around,great site
Old Oct 3, 2004 | 07:59 PM
85_305's Avatar
Re: Which cam?
Thanx for the web-addy's everybody, but the thing is.. I don't know the first thing about choosing a cam I relize that the higher the lift, the sweeter, meaner, and more America Muscle sounding the car will be; and that by putting in a high-lift cam the top-end of the car will be amazing; and that the idle of teh car will suck gas horribly; But that is about it. I know really nothing else. When I say "I dont want it to suck gas", I relize my car is gonna suck gas either way I go. But I mean, I dont want the cam to take away like 4-mpg. After reviewing that Clevite website, I am thinking that I want something around 195' or so.. but it says that you can not have more than 9.0:1.. My Camaro has 9.5:1.
Any help?
Old Oct 4, 2004 | 12:57 AM
AutoNewb's Avatar
Re: Which cam?
I hear ya man. I figure i might as well buy a camaro...you put a performance throttle body, cold air intake and secret cams on a grand am gt and yer already gettin gas mileage on a 350 lol.
Old Oct 4, 2004 | 06:41 AM
teke184's Avatar
Re: Which cam?
40-104221 Crane Cams CompuCam 2030 Hydraulic Roller Camshaft, 204 / 214, .429 / .452 116 LSA, For factory roller cam engines with TPI or TBI and stock computer. Adjustable fuel pressure regulator recommended. $264.99 Buy Wish
40-104224 Crane Cams CompuCam 2032 Hydraulic Roller Camshaft, 214 / 220, .452 / .465 112 LSA, For factory roller cam engines with modified TPI or TBI and modified computer. Adjustable fuel pressure regulator recommended. $264.99
40-104225 Crane Cams CompuCam 2031 Hydraulic Roller Camshaft, 208 / 214, .438 / .452 112 LSA, For factory roller cam engines with TPI or TBI and stock computer. Adjustable fuel pressure regulator recommended. $264.99
id say one of those cams
but honesly, since you know so little about engines, particularly camshafts, maybe that is not the wisest modification right now.
Old Oct 4, 2004 | 01:49 PM
85_305's Avatar
Re: Which cam?
I actually know quite a bit for a 17 year old about engines (not that THAT is saying much..) but cams are totally diff. for me. It is moreso an ART to cam something, and to ground up cams.. not just an easy choice. But that is why I am consulting this board, as I know very little about cams. I am hoping that this board will be a little bit of help in my little quest.
Old Oct 4, 2004 | 02:46 PM
Tru2Chevy's Avatar
Re: Which cam?
Actually, none of the cams you mentioned will work for him, without investing in an expensive aftermarket roller setup. Read the sig....his car is an '85, so it will be a hyd. flat tappet LG4...only the '87 LG4's were roller motors from the factory.
- Justin
Old Oct 4, 2004 | 04:00 PM
85_305's Avatar
Re: Which cam?
Aren't hydrolic rollers a good thing to get as factory equiped?
Old Oct 4, 2004 | 04:32 PM
85_305's Avatar
Re: Which cam?
Thanks Gunny, I will keep those numbers in mind
Old Oct 4, 2004 | 04:37 PM
Re: Which cam?
yes.
